What type of headers are you guys running on your b16a's ??
Old Mar 27, 2003 | 12:14 PM
Fred n J_v2.0's Avatar
Default What type of headers are you guys running on your b16a's ??
Just wondering what type of headers you guys are running on your b16a? Also, why did you go with that setup and how is the clearance? Any other advice/suggestions b/c I am lookin for a header and I dont want to run into some problems...
Thanks,
Julian
Old Mar 27, 2003 | 12:15 PM
ElementMotor's Avatar
Default Re: What type of headers are you guys running on your b16a's ?? (95VXFRANK)
I was using the DC 4-1 on my last swap. My crx was slammed and it scraped every once and a while but nothing too major.
Old Mar 27, 2003 | 12:23 PM
mr. wu's Avatar
Default Re: What type of headers are you guys running on your b16a's ?? (EF8 ownz u)
i too am running with the dc 4-1 really no problems, but it rubs on my front crosmember. it's no big deal thow
Old Mar 27, 2003 | 12:28 PM
cornholioEK's Avatar
Default Re: What type of headers are you guys running on your b16a's ?? (mr. wu)
i have the 4-2-1. its mad bent. i need a new one. my car was too low
Old Mar 27, 2003 | 12:43 PM
CRX7's Avatar
Default Re: What type of headers are you guys running on your b16a's ?? (DOHCvtecCR-X)
DC 4-2-1 with 2 1/4 inch collector/piping at the 2-1 merge. Scraped but not bent yet. I've also been using a single stock 1-wire 02 sensor near the collector, I would suggest using a 4-wire 02 sensor as my car doesn't run the best.
Old Mar 27, 2003 | 12:53 PM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
Default Re: What type of headers are you guys running on your b16a's ?? (CRX7)
Comptech tig stainless 4-2-1 with 1 o2 in the stock 99-00 b16a2 location. Running absolutely beautifully with a Hondata Stage 2 (tapped the 2nd o2 into the 1st o2). I got the header because its one of the best USDM headers out there, without spending money for the bling factor of a JDM spoon, mugen, etc....
Pics in my sig of ground clearance, and crossmember clearance...no modification necessary.
-Todd
Old Mar 27, 2003 | 02:46 PM
Patch's Avatar
Default Re: What type of headers are you guys running on your b16a's ?? (Count Blah)
Hey Count, what is that CAI off of? Since I see no battery, I'm assuming you put it in the back? Are you using your normal battery or one of those sealed *****?
Old Mar 27, 2003 | 08:37 PM
Count Blah's Avatar
Default Re: What type of headers are you guys running on your b16a's ?? (CRX PAT)
Its an AEM CAI from a 99-00 Civic Si. I ran the battery to the back (there are some pics of it in my sig) and im using a stock battery inside a sealed box. Im pretty much at the point in my life where if i get scalded by hot battery acid it will be a good thing...
-Todd
Old Mar 27, 2003 | 09:20 PM
hcarcrx's Avatar
ive always used dc headers ( more than 1 crx) on what ever ive done!! ive have a 421 on my car now with a 2nd o2 bung welded into it! i have found these headers make more power than any outher header out there!!!
Old Mar 27, 2003 | 10:08 PM
CRX7's Avatar
Default Re: What type of headers are you guys running on your b16a's ?? (hcarcrx)
the primaries and secondaries are just too small on the DC. I would prefer the an-r header.
Crx 707 Si
Jul 30, 2005 08:19 PM
cvccjdm
11
Nov 3, 2004 12:25 PM
drjondurst
Mar 28, 2003 05:59 PM
brent_G
Apr 1, 2002 11:21 PM
BuddhaSiR
13
Oct 25, 2001 01:49 PM
