Car dies immedately after starting
Old Mar 27, 2003 | 10:51 AM
Prentice's Avatar
Default Car dies immedately after starting
Hi, I have an 85 Honda Accord-LX 1.8L. Today I went out to go somewhere and tried to start my car. It started, but immediately turned off after its initial rev. I did this about 20 times and the same thing. This happened the other day as well but it eventually started after 2 or 3 times. Nothing when I pump the gas. It just revs like normal then goes back to nothing. I haven't tried changing the fuel filters yet as I can't get to the store so I just decided to post here to see what you guys think.
Old Mar 27, 2003 | 11:08 AM
Stripped Honda's Avatar
99-0104
Default Re: Car dies immedately after starting (Prentice)
sounds like a fuel problem either carb or fuel pump
Old Mar 27, 2003 | 03:09 PM
Chiovnidca's Avatar
Ignition switch maybe. Do the dash lights go out when it stalls?
Old Mar 28, 2003 | 10:23 AM
Prentice's Avatar
Default Re: Car dies immedately after starting (TurboD16Chiovnidca)
no they dont, the car doesn't ever lose power. I was looking around and maybe it has to do with the main relay..although also from looking around I've seen that main relays only show up in diagrams on fuel injected cars..
Old Mar 28, 2003 | 12:18 PM
accord91h22's Avatar
I know on my 91 when it did that it was the fuel pump relay.
Old Mar 28, 2003 | 12:49 PM
JimBlake's Avatar
I haven't had a carburator since my '72 Datsun, but FWIW...
Sounds like the orifice to the main or idle jets is plugged. Its only getting gas from the initial shot from the accelerator pump.
Time to overhaul the carb. That was always a normal maintenance thing & you used to be able to get carb rebuild kits from the corner autoparts store.
Old Mar 28, 2003 | 09:56 PM
KoJiRoH3k's Avatar
Check your alternator and battery, see if the alternator is recieving full current and if it's discharging your battery.
Old Mar 31, 2003 | 03:20 PM
iam7head's Avatar
Default Re: Car dies immedately after starting (KoJiRoH3k)
check the freaken map sensor
Old Apr 2, 2003 | 07:47 AM
JimBlake's Avatar
Default Re: Car dies immedately after starting (iam7head)
mmmm... where would that be located on a carburated engine?
Old Apr 2, 2003 | 02:04 PM
Chiovnidca's Avatar
Default Re: Car dies immedately after starting (JimBlake)
Is it next to the fuel presure regulator?
StegRX
Feb 8, 2016 07:54 AM
Broke_not_built
Aug 22, 2011 10:40 AM
italstallion
Jul 11, 2006 03:04 PM
2camsaam
18
Apr 13, 2004 03:47 AM
2camsaam
Jul 14, 2003 09:09 AM
