Code 17 Vehicle speed sensor
Old Mar 26, 2003 | 07:22 PM
crexer's Avatar
Default Code 17 Vehicle speed sensor
wil this cause the check engine light to come on?
Old Mar 26, 2003 | 08:37 PM
Fobtions's Avatar
Default Re: Code 17 Vehicle speed sensor (crexer)
yes, if you have something wrong with the vss, you will not be able to engage vtec unless you have a vtec controller. the check engine light won tbe on right away, but after you go past 20? mph then to a stop.
Old Mar 26, 2003 | 08:55 PM
crexer's Avatar
Default Re: Code 17 Vehicle speed sensor (Fobtions)
we'll theres no vtec in my 1.5 dx motor; but I did realize that it came on after I drive for a little while
Old Mar 26, 2003 | 10:30 PM
EF-9SiR's Avatar
i have a b16, my electronic VSS isnt hooked up, so im getting a 17 CEL, but my vtec still engages....
Old Mar 26, 2003 | 10:38 PM
ThatRicerDaniel's Avatar
cel17 can be more than the vss be hooked up or not . for example if your missing a screw or if somthing isnt pluged in the on the back of the cluster than you could get a 17 .. lots of differeent reaons.
Old Mar 26, 2003 | 10:47 PM
pokemon's Avatar
Default Re: Code 17 Vehicle speed sensor (NitrousDreamz)
When my VSS wasn't hooked up at the tranny on my 91 hatch w/ b16 using the PW0 Ecu my VTEC wouldn't engage. Fixed that problem though. ;]
Old Mar 26, 2003 | 11:59 PM
RuthlessEF-9's Avatar
sure will
Old Mar 27, 2003 | 06:26 AM
RuffRhyno's Avatar
On another note, I have heard several different answers to this question...Will a code 17 cause your motor to run rich? At least, richer than normal?
Old Mar 27, 2003 | 07:35 AM
blackrex91's Avatar
i have a 91 crx dx and i got the same code with the check engine light on. when i put my new transmission in i didnt have the speedo cable in the trans. far enough. i felt like an idiot. by the way my speedo didnt work either.
Old Mar 27, 2003 | 07:43 AM
Scarface928's Avatar
From: Northern Virginia home of missing hondas, USA
The speedo cable is loose by the cluster or on the tranny.Most of the time that's the problem.Yes you will have the check engine light appear after going about 30 mph.
Old Mar 27, 2003 | 07:26 PM
crexer's Avatar
Default Re: Code 17 Vehicle speed sensor (Scarface928)
speaking of running rich my car is with the code; im gonna try several things out tomorrow and see whats up with it
E36 Guy
Dec 11, 2003 03:15 PM
E36 Guy
Dec 9, 2003 10:21 PM
E36 Guy
Dec 9, 2003 08:49 PM
DumpedSi
Sep 8, 2003 04:18 PM
HaUTSaauce
Mar 30, 2002 07:12 PM
