Need guidance before ordering B16.
I will be ordering a B16 for my CRX DX within the next week from passwordjdm.com. I am getting it installed at my local Honda dealership for $600 as well as $350 for the DPFI to MPFI swap. I just want to make sure this is really EVERYTHING I will need to deliver to them to have the swap completed.
As it says on the passwordjdm.com website:
motor, tranny, clutch/flywheel, axles, ecu, shift linkage, all attached components... starter, alternator, sensor, t.body, JDM wire loom, distributor, and everything is still intact!!! standard start up warranty applies to all motors!!!
... and I've already got Hasport mounts. Is this everything? They guy I talked to said I would need 86-89 Integra half-shafts. I've never heard of someone mentioning this for a B16 to CRX swap. Do I need them? Thanks for your help.
[Modified by camera obscura, 3:44 AM 3/27/2003]
Dont use that axles that come with it, use 90-93 axles and intmed. shaft. uhh do a search for the rest of the stuff your gonna need. theres another thread floating around that has all the stuff that you need. or do a search.
good luck
Blaze
good luck
Blaze
Im sure you can sypathize with me considering my lack of experience and the large financial investment. But thanks.[Modified by camera obscura, 3:41 AM 3/27/2003]
Did you get the Hasport modified shift linkage? You will need this too, unless you buy a 90-93 Teg shift linkage, and modify it yourself.
Woah what Honda dealership does that?
my local dealership won't even replace my cat if it has an aftermarket full cat-back exhust on it
(an example)
(an example)
Also, are you going to be replacing anything when you get the swap? ie..timing belt, water pump, clutch
hondatuner020
12
Dec 27, 2007 06:32 AM
freak86
Oct 20, 2006 07:51 PM
