help!! cant mount manifold and turbo....
how do i fix this?
the wastegate is hitting the block, and preventing me from mounting the turbo and manifold on... i have a t3 off a saab internally wastegated...what would I have too do too run an external wastegate? or could I somehow move the internal wastegate??oh, right now i am running a hf manifold with some sort of adapter...would a different manifold help me??
You can either run a different manifold.
Run thicker (such as Mr.Gasket copper-seal) or more gaskets (ghetto)
Grind the webbing on the block, if that's where it's hitting? I had to take a ****-load off of mine and it's still touching...my solution will most likely be a different turbo when I have the time/money.
Or you can use an external wastegate. To do this you will need a place to attach it to the manifold (might be easier to get a different manifold) and will have to use a downpipe that blocks off the internal wastegate port.
