help!! cant mount manifold and turbo....
Old Mar 26, 2003 | 01:11 PM
GOLDBERG's Avatar
Default help!! cant mount manifold and turbo....
how do i fix this? the wastegate is hitting the block, and preventing me from mounting the turbo and manifold on... i have a t3 off a saab internally wastegated...what would I have too do too run an external wastegate? or could I somehow move the internal wastegate??oh, right now i am running a hf manifold with some sort of adapter...would a different manifold help me??
Old Mar 26, 2003 | 01:31 PM
ion_four's Avatar
Default Re: help!! cant mount manifold and turbo.... (GOLDBERG)
You can either run a different manifold.
Run thicker (such as Mr.Gasket copper-seal) or more gaskets (ghetto)
Grind the webbing on the block, if that's where it's hitting? I had to take a ****-load off of mine and it's still touching...my solution will most likely be a different turbo when I have the time/money.
Or you can use an external wastegate. To do this you will need a place to attach it to the manifold (might be easier to get a different manifold) and will have to use a downpipe that blocks off the internal wastegate port.
Old Mar 26, 2003 | 01:58 PM
TeStUdO's Avatar
Default Re: help!! cant mount manifold and turbo.... (ion_four)
yeah i had to grind my block too and im using an external wastegate. sucks but it worked
Old Mar 26, 2003 | 04:10 PM
GOLDBERG's Avatar
Default Re: help!! cant mount manifold and turbo.... (00si5)
what internal wastegate "port"?? I only got one hole from the exhaust housing that I can see..
Old Mar 26, 2003 | 04:31 PM
b16ahybrid's Avatar
take the part that is connected to the exhaust housing off (should be three bolts) then you will see the wg hole and flapper....
sasinorm01
Mar 14, 2008 08:14 PM
12x
Sep 20, 2006 08:30 AM
