Crx still running hot
I replaced the radiator on this crx. The previous owner said a shop told him he needed it and by looking at the old one I'd say yes. He also put a new cap and thermostat.
I followed all directions and it still is running hot. Not as hot as it was before. But the needle is 3/4 of the way up. It won't creep up until I drive it for a couple of minutes. It will sit in idle without going above the half way mark for a while no problem. The fan comes on like it should, I don't see any leaking anywhere.
How sensitive are these models to correct mixture of coolant? I don't see any signs of head gasket failure. If the system isn't bleed correctly could it cause it to heat up?
Thanks, I'm a holding out hope that it's not the head gasket.
