what turbo or supercharger would you recomend for a ....
Old Mar 25, 2003 | 01:41 PM
maddog's Avatar
Default what turbo or supercharger would you recomend for a ....
..... 1.5 l4... the engine is in a 91 honda hb si. i have never heard of the engine but i dont a whole lot about the different engines in all the different hondas. the lemon check said the engine was a 1.5 l4 but the model said that is was a 91 si hb.
thanks
Old Mar 25, 2003 | 01:47 PM
Killa's Avatar
Default Re: what turbo or supercharger would you recomend for a .... (maddog)
i think you'd be better off with a motor swap, your motor's just too small.
Old Mar 25, 2003 | 01:49 PM
keebler65's Avatar
Default Re: what turbo or supercharger would you recomend for a .... (HondaKilla)
if its an si like you say it is, then you *should* have a D16a6 motor, which is 1.6L. check the engine code under the hood to make sure. i've heard of people bolting turbos onto these, although its not as common. jackson racing makes a sc kit for that motor, but i wouldnt recommend it from what i've heard over the years.
Old Mar 25, 2003 | 01:52 PM
maddog's Avatar
thats the thing my engine is to small for the boost you people want to put on it (20 psi and what not). I would want like7 to 12 psi. just enough to stomp a little *** but still be healthy for muh engine
Old Mar 25, 2003 | 02:04 PM
keebler65's Avatar
a D16A6 could handle 6psi reliably and run a long time without problems, assuming its tuned well. i'm sure people get away with 8 or so even, but i'm not that risky.
Old Mar 25, 2003 | 03:18 PM
maddog's Avatar
Default Re: what turbo or supercharger would you recomend for a .... (keebler65)
but im not sure if its even that motorr. any more input
Old Mar 25, 2003 | 03:46 PM
keebler65's Avatar
then you may want to go out and read the code before looking for more input. the code is between the engine and tranny (to the left of the exhaust manifold).
Old Mar 25, 2003 | 04:23 PM
maddog's Avatar
thanx... but see i havent bought the car yet
Old Mar 25, 2003 | 04:30 PM
keebler65's Avatar
ahh that makes more sense. well like i said, as long as you're positive its an Si, then it will have the 1.6 in it. many times those online sites are inaccurate.
Old Mar 25, 2003 | 04:49 PM
keebler65's Avatar
after doing a quick search, i found this thread for you:
https://honda-tech.com/zerothread?id=448827
Old Mar 26, 2003 | 10:18 AM
maddog's Avatar
thank you much
Old Mar 26, 2003 | 10:28 AM
MikeMAN's Avatar
nm
[Modified by MikeMAN, 1:28 PM 3/26/2003]
zrs6v4
Sep 27, 2009 04:51 PM
JASON77
Apr 24, 2009 07:31 AM
Siberian Husky
Sep 6, 2005 08:05 AM
nfuchs80
Jun 6, 2004 07:08 PM
Chikelu98
Dec 10, 2003 10:49 PM
