what turbo or supercharger would you recomend for a ....
..... 1.5 l4... the engine is in a 91 honda hb si. i have never heard of the engine but i dont a whole lot about the different engines in all the different hondas. the lemon check said the engine was a 1.5 l4 but the model said that is was a 91 si hb.
thanks
thanks
Re: what turbo or supercharger would you recomend for a .... (HondaKilla)
if its an si like you say it is, then you *should* have a D16a6 motor, which is 1.6L. check the engine code under the hood to make sure. i've heard of people bolting turbos onto these, although its not as common. jackson racing makes a sc kit for that motor, but i wouldnt recommend it from what i've heard over the years.
thats the thing my engine is to small for the boost you people want to put on it (20 psi and what not). I would want like7 to 12 psi. just enough to stomp a little *** but still be healthy for muh engine
Re: what turbo or supercharger would you recomend for a .... (maddog)
a D16A6 could handle 6psi reliably and run a long time without problems, assuming its tuned well. i'm sure people get away with 8 or so even, but i'm not that risky.
then you may want to go out and read the code before looking for more input. the code is between the engine and tranny (to the left of the exhaust manifold).
thanx... but see i havent bought the car yet
Re: what turbo or supercharger would you recomend for a .... (keebler65)
after doing a quick search, i found this thread for you:
https://honda-tech.com/zerothread?id=448827
zrs6v4
09-27-2009 04:51 PM
Chikelu98
12-10-2003 10:49 PM
