Whats needed for a k20a swap in a ep3??
I am just seeing what I would all need in a k20a swap in a ep3. I see they have a engine package at hmo for 5800. it includes Motor
- 6-speed LSD Tranny 4.7 Final Drive (Y2M3)
- ECU (PRC)
- Stock Motor Mounts
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
that about sums it up doesnt it? Why dont I need axles in this swap???Thanks for the help
Troy
- ECU (PRC)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Troy
You do not necessarily need the computer.
Hondata can reflash your existing computer with a program that is better then the stock ITR program.
See http://www.hondata.com/k20arelease.html for details
You should be able to retain the stock axles.
Would it be cheaper to put a k20a head on the a3, upgrade the pistons, swap for a type r tranny?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S-fiend »</TD></TR><TR><TD CLASS="quote">And oh course the itr int. mani. and exhaust mani.</TD></TR></TABLE>
it would be cheaper, but wouldn't necessarily be comparable. the k20R head revs much higher than what the a3 block could safely support. this topic has actually been beaten to hell on this board if u search a little bit. redstone motors in mountain view, ca had a couple k20a's for sale with everything you need for a great price... i'd reccomend them, good peoples too. if you don't want to spend the money to get the k20a, don't half step it, just get a k20a2 or even a k24a2 and you'll be much happier than you would be if you added all those parts to the a3 block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starbuc »</TD></TR><TR><TD CLASS="quote">how high does the k20-R motor rev?</TD></TR></TABLE>
stock is 8400
stock is 8400
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnkimble »</TD></TR><TR><TD CLASS="quote"> redstone motors in mountain view, ca had a couple k20a's for sale with everything you need for a great price... i'd reccomend them, good peoples too.</TD></TR></TABLE>
$5500 is a great price? not that bad, but great?
I'm lookin for a $5000
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HalvieCuw »</TD></TR><TR><TD CLASS="quote">but would the part I listed be all I would need for the swap?</TD></TR></TABLE>
You might actually be going overboard. Your USDM EP3 already has the Type R axle ratio and good gear ratios in the transmission.
Maybe you should just get an LSD and forget the six speed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Halo »</TD></TR><TR><TD CLASS="quote">damn $5k is allot of feddy for a damn motor
how much do you think it owuld cost to have an all motor B series build hit 200whp?
</TD></TR></TABLE>how much do you think it owuld cost to have an all motor B series build hit 200whp?
[Ennis_D]
Aug 19, 2004 10:25 PM
