exhaust cams
Old Mar 24, 2003 | 07:29 PM
granada_sun's Avatar
Default exhaust cams
would there be any improvement to replacing a b16 exhaust cam with a gsr one?
sorry if this has been posted a thousand times, the search function isn't working....
Old Mar 24, 2003 | 09:49 PM
Default Re: exhaust cams (Dark_Sol)
humpty bumpty
Old Mar 25, 2003 | 11:06 AM
nobody knows the lift and duration of gsr cams huh?
Old Mar 25, 2003 | 11:55 AM
Katman's Avatar
well, it depends on what year your B16 cams are.
If they're 92+ B16 cams, they're fairly close in spec to 94+ GSR cams.
If you own 89-91 B16A cams, then by golly, yes get both GSR cams, as 89-91 B16A cams are of weaker spec.
Old Mar 25, 2003 | 01:13 PM
Default Re: exhaust cams (Katman)
the motor is 2nd gen b16.
I was hoping to get type r intake cam, then swap in a gsr exhaust cam cause it'd be cheaper than another type r cam.
Old Mar 25, 2003 | 01:27 PM
Katman's Avatar
true..
but its best to run both 'R' cams; people say the 'R' exhaust cam is exactly like a stock B16 or GSR exhaust cam....total BS. The primary and secondary lobes are close to stock b16/b18c spec, but the MID or VTEC lobe is where it differs ...
Old Mar 25, 2003 | 01:42 PM
keebler65's Avatar
i heard first gen b16 EXHAUST cams are identical to the gsr, and that only the gsr INTAKE cam is better???
Old Mar 25, 2003 | 02:18 PM
Katman's Avatar
Default Re: exhaust cams (keebler65)
That depends on which year GSR cams you speak of...
B17A/GSR (92-93) or B18C/GSR (94-00)
the B17/GSR cams are slightly better than the 89-91 B16 cams.
89-91 B16 cams AT or MT, are pretty gay specs in general. You're best of with a set of 92+ B-series cams.
Old Mar 25, 2003 | 02:28 PM
keebler65's Avatar
ok thanks for clearing that up. maybe this post will help someone out as well....this is the results of my cam swap from b16 to gsr:
https://honda-tech.com/zerothread?id=449629
however, i swapped both intake and exhaust, so i guess we wont know how much the exhaust helps. the only reason i did this swap was becuase the JRSC is supposed to love the GSR cams. if you're staying NA, do NOT put in GSR cams, it would be a waste of time and money, as you can see in the link.
Old Mar 25, 2003 | 02:53 PM
Yeah to hell with that then, the search for a decent priced set of TR cams is about to commence.
Thanks for the input fellas.
97_coupe
Feb 26, 2008 03:08 PM
ef-b16sedan
Aug 6, 2006 01:22 PM
unclepowers
Sep 23, 2005 10:27 AM
PYITR821
Jun 9, 2002 01:07 PM
LB CRX
May 6, 2002 11:26 PM
