an idea about turbos and sc's
Old Mar 24, 2003 | 12:24 PM
keebler65's Avatar
Default an idea about turbos and sc's
i was recently discussing the differences between turbos and sc's with someone, and i pointed out how the JRSC puts less wear on a motor while cruising since it has the bypass valve.
my question is, why dont you turbo guys hook up your bov so that it stays open for cruising and then closes instantly when the throttle increases? wouldnt this make for less wear and tear on your motor while cruising?
btw i want to see some of the profits when you start selling my idea
Old Mar 24, 2003 | 12:27 PM
b18bturbo's Avatar
Default Re: an idea about turbos and sc's (keebler65)
You are not doing any damage when cruising in turbo car. You car is in vacuum or close to 0psi. You only start making boost when there is load and accelration.
Then by that time when you left of the gas the bov will open therby alleviating compressor surge.
In other words your theory is way off...
[Modified by b18bturbo, 3:28 PM 3/24/2003]
Old Mar 24, 2003 | 12:56 PM
GreddySi99's Avatar
Default Re: an idea about turbos and sc's (b18bturbo)
844 posts and you didn't know that
Old Mar 24, 2003 | 01:07 PM
keebler65's Avatar
Default Re: an idea about turbos and sc's (intercooledJRSC)
no, as i am relatively new to FI. so much for that idea
Old Mar 26, 2003 | 06:05 PM
smallttocs's Avatar
hes a supercharger guy
ok... the BOV opens when you let off the gas... so does it close when you put gas back to it? in other words... when exactly does it close?
[Modified by smallttocs, 9:07 PM 3/26/2003]
Old Mar 27, 2003 | 02:43 PM
smallttocs's Avatar
Default Re: an idea about turbos and sc's (smallttocs)
anyone?
Old Mar 27, 2003 | 03:41 PM
QCKGSR's Avatar
sweet idea go with it
Old Mar 27, 2003 | 04:28 PM
MooreBoost's Avatar
Default Re: an idea about turbos and sc's (QCKGSR)
Read the whole post dipshit. As for intercooledJRSC....Do you actually have an intercooled JRSC?
gmoore
Old Mar 28, 2003 | 12:43 AM
Stu's Avatar
Stu
New User
Yes. The BOV is controlled by a vacuum line that goes to your intake manifold. When the BOV senses vacuum, it opens the BOV, the second that you open the throttle plate again, that vacuum goes away and the BOV closes agian.
xkrntamax
Dec 3, 2007 01:55 PM
astig* DC2
Jun 17, 2005 10:33 AM
M-Type
Feb 26, 2003 01:26 AM
TallGuyDC2
Aug 8, 2002 10:07 PM
osbornsm
Oct 1, 2001 06:51 AM
