ALL-MOTOR --- What do you think of this LS/VTEC setup?
Old Jun 15, 2001 | 02:12 AM
Shoe's Avatar
New User
Default ALL-MOTOR --- What do you think of this LS/VTEC setup?
Air Flow:
HP Cold Air Intake
HP 4-2-1 Headers
Hi-Flow Cat
Custom 2.5 inch Exhaust
Arospeed muffler
Drivetrain:
GS-R Tranny w/LSD
Clutch Masters Stage 3
Clutch Masters 9lb Flywheel
Head:
B16A Head (Kit w/everything needed)
Type R Cams
Type R Springs/Retainers
Port & Polish
64mm Throttle Body
HP Intake Manifold w/Rail
Computer/Fuel:
GS-R ECU
MSD Ignition
290cc Injectors
Venom 400 Performance Control Module
B&M Fuel Pressure Regulator w/gauge
Bottom End:
B18B1 Block
ITR Pistons
Shot-Peened Rods
Blueprint/Balance
Don't ask about the HP stuff (I'm either A. sponced by HP, B. Obsessed with HP or C. Both A and B Combined).
What do you think of this LS/VTEC setup? What would you change/modify/add?
Old Jun 15, 2001 | 04:06 AM
Mike D's Avatar
Default Re: ALL-MOTOR --- What do you think of this LS/VTEC setup? (Shoe)
sounds liek an excellent set-up. Do you know what kind of numbers you will get?
Old Jun 15, 2001 | 05:29 AM
radiac's Avatar
New User
why not go with some wilder cams? (spec bs, perhaps?)
Old Jun 15, 2001 | 12:03 PM
Shoe's Avatar
New User
Default Re: ALL-MOTOR --- What do you think of this LS/VTEC setup? (radiac)
I'd be happy with 180whp.
Type Rs are find for my application. No need for me to spend all those extra dollars on the spec Bs, won't get enough the gains for the $$, don't have the money or fasilities to dyno tune them..
keep it commin'
Old Jun 15, 2001 | 12:31 PM
X2BOARD's Avatar
I don't know about he HP headers.... haven't heard the best stuff about them over here (made in FL). But WHO CARES !! The setup sounds SWEET !!
I intend on going LS/Vtec some time in the future (running a B18B1 now)
I'll buy the setup off ya !
Did you already have it installed ? How does it pull ?
X2 is : JEALOUS
Old Jun 15, 2001 | 12:44 PM
ezark's Avatar
Nice setup- only thing i'd change is the " 4-2-1 " headers to "4 - 1" perhaps the JDM 4-1
Old Jun 15, 2001 | 12:45 PM
P73 DA9's Avatar
New User
If I were you, I would not go with the GSR ecu. One guy at Dynamics recommnded a p28 ecu while another guy there recommended a GSR ecu. The guy who recommended the GSR ecu told me to trust him, it is a good ecu for my LS/VTEC set up. I ended up getting a GSR ecu and I put it in. I had the car tuned with that ecu and it was like 170. The only problem was that the check engine light was always on. I do not have a knock sensor in my car and my spedometer is cable driven instead of electrical. I have sisnce then spoke to many people who highly recommend the p28 over the GSR ecu, just get the P28 programmed to fit your car. Other than that, I think you will be running strong with the set up you have chosen
Old Jun 15, 2001 | 01:24 PM
Shoe's Avatar
New User
Default Re: ALL-MOTOR --- What do you think of this LS/VTEC setup? (blueG2)
Is the P28 a mugen program?
I'll need a VTEC ecu correct?
Old Jun 15, 2001 | 01:25 PM
Shoe's Avatar
New User
Default Re: ALL-MOTOR --- What do you think of this LS/VTEC setup? (X2BOARD)
Give me 1 year!
Old Jun 15, 2001 | 05:00 PM
randyman's Avatar
New User
since u'll be using a b16 head, ditch the gsr ecu and get a b16 ecu, p28 ecu reprogrammed for dohc vtec -- mugen program/skunk/whatever, or an ITR ecu. if ur OBD1 just go with the first 2 ecu's that i mentioned -- these are just suggestions, there's more combos that i can dish out but it'll take too long for me discuss it.
anyway, the reason that the GSR ecu is not "suitable" for ur setup is due to that fact that u don't have secondaries. a reprogrammed p28 would be good for ur setup (b16 head).
lates.
Old Jun 15, 2001 | 05:15 PM
HondaIntegraLS's Avatar
I hope you are not obsessed with HP. I only say that because I am a distributor (well was) and was not even close to pleased with the quality of crap they sent me when they began. I can say for sure the junk was not safe to put on as suspension, let alone to use as a paper weight. If they have improved then by all means enjoy. If not, I wish you the best with their crap.
Old Jun 15, 2001 | 07:49 PM
Shoe's Avatar
New User
Default Re: ALL-MOTOR --- What do you think of this LS/VTEC setup? (HondaIntegraLS)
LOL, i'v changed the following things:
HP Intake manifold ----- to ------ Type R manifold
HP 4-2-1 Headers ----- to ----- JDM Headers maybe?
I'll keep the HP intake.. no sense changing it to AEM not worth the $$ to me.
kxrider25
Mar 27, 2011 09:28 AM
zachv365
Aug 26, 2009 08:04 PM
sluggo
Sep 19, 2007 01:52 AM
Newb_civic
Jun 2, 2007 04:54 AM
baam
Sep 13, 2005 05:18 PM
