Hondata Full Throttle Shifting
Old Mar 23, 2003 | 06:30 PM
gsrvx's Avatar
New User
Default Hondata Full Throttle Shifting
I'm going to be installing the clutch switch tomorrow for it and I was wondering if what experiences you guys have had with this hondata feature.
-Rod
Old Mar 23, 2003 | 06:38 PM
zer0zer0 TypeR's Avatar
Default Re: Hondata Full Throttle Shifting (RK)
Don't install it, especially if you like to have room to "play" with your clutch.
Old Mar 23, 2003 | 06:42 PM
gsrvx's Avatar
New User
Default Re: Hondata Full Throttle Shifting (zer0zer0 TypeR)
Can you explain?
Old Mar 23, 2003 | 06:45 PM
basically if you're redlining through all gears, you absolutely CANNOT have your foot on the clutch, if you do, the rev limiter will just stay at what you set it at. So if you have the full throttle shifting rev limiter at say 7K like i have mine, and you try to redline through gears for a drag race, you better have your foot off the clutch or the fullthrottle shift button will be engaged and you'll end up topping out at 7K if that sensor is triggered. It's a useless feature to have, i recommend not installing it. I'm about to pull mine but too lazy to do so
Old Mar 23, 2003 | 09:13 PM
rodimus's Avatar
good to know.
video of it looked cool though...but i guess that's about it...
Old Mar 23, 2003 | 09:29 PM
nfn15037's Avatar
You shouldnt have your foot on the clutch anyways. Also, there has to be a way to make is not so sensitive?
Old Mar 23, 2003 | 10:19 PM
gsrvx's Avatar
New User
Default Re: Hondata Full Throttle Shifting (nfn15037)
so I should probably set the shift limit point something higher than redline...so it doesn't kick in...because I still want to be able to use launch control.
-Rod
Old Mar 23, 2003 | 11:10 PM
R-1303's Avatar
Can't you put the buttons somwhere else?..lets say for the launch control..i would use a push button where the e-brake is so i would just rev and press the button.
Old Mar 24, 2003 | 02:23 PM
madslackin's Avatar
Launch limiter and full throttle shift limiter are two different settings.
You shouldn't be running into your launch limiter at any time after your initial launch.
Full throttle shift is not a "useless option"; you're just not using it right.
Justin
Old Mar 24, 2003 | 03:19 PM
gsrvx's Avatar
New User
Default Re: Hondata Full Throttle Shifting (madslackin)
Oh I know. I think what I wrote was confusing. He was telling me to ditch the full throttle but if I disconnect the clutch switch..I won't be able to use the launch control feature...that's what i meant.
-Rod
Old Mar 24, 2003 | 04:58 PM
PM-Performance's Avatar
i have mixed \feelings about it .i hooked mine up thise week and just unhooked it , the fucknig thing was kckkng a revlimiter at 6k for some someeasno ? it would be cool if i could get it to work right though, i hate to hold in a button for my 2step i rather just use the clutch switch, .. . any ideas on why mine does this?
Old Mar 24, 2003 | 08:58 PM
gsrvx's Avatar
New User
Default Re: Hondata Full Throttle Shifting (itr206)
Are you touching the clutch? I'm assuming that's why ur limiter is kickin in @ 6K. Has anyone had success with the full throttle shifting? Seems like majority don't like it.
-Rod
Old Mar 24, 2003 | 09:04 PM
seanb18c1's Avatar
I'm asuming you have the s2oo, you can install the switch on the clutch just don't plug it in to the blue box until your ready to launch you car. Or you can rig up a kill switch.
Old Mar 24, 2003 | 09:25 PM
gsrvx's Avatar
New User
Default Re: Hondata Full Throttle Shifting (seanb18c1)
stage 3...not the s200
turbotime
Jan 31, 2005 09:03 AM
Boostage
Feb 23, 2004 01:53 PM
crx1856
Oct 25, 2003 04:56 PM
steebypue
Apr 24, 2003 09:08 AM
PM-Performance
Mar 25, 2003 04:59 PM
