turbo with no fuel management???
sup guys im having alot of problem with the smc+. im plannnig to do the uberchip. so im taking off the 450cc and the smc off but leaving the turbo on there. im install the stock injectors back on so i can drive to school. would it be ok to leave the turbo on there and dont boost at all until i get the chip and ecu and stuff. i will watch the gauge very carefully and stay out of boost. would that be ok?
if you have a internal wastegate,disconnect it so you cant make boost.when i saw disconnect it i mean actually remove the rod from the valve,not the vacuum line.
you realize u can reach full boost with the wastegate complete off on a 14b right? Your turbo is too small todo that with. if you had a masive turbo you could get away with it. If you really want todo this, take off oyur charge piping. Put a cap on the compressor's inlet, poke a small 1/8" hole in it. Then do the same for the outlet.
edit: this doesnt mean you can floor he gas and drive aroudn hard. Just drive it easy.
[Modified by UberTeg, 1:44 AM 3/24/2003]
allmotor_dm
Jan 24, 2006 06:07 PM
