si to vtec harness soldering
im trying to wire my subharness for vtec and im stripping the wires twisting them tight and then using sodder. is this going to be a good enough connection or will i throw codes? any advice?
depends on the resistance that you soldier in? If you do a cold joint your screwed. Make sure you do a good job. You could do what I did and order a Hasport wire Harness?
B_SERIES_BITCHEZ!
May 21, 2006 08:49 PM
