vibration in gas pedal
Old Mar 22, 2003 | 10:15 PM
accord94's Avatar
Default vibration in gas pedal
ok, so lately at around 2500 rpm I get a noticeable (not huge) vibration through my gas pedal. It usually only happens in second gear. If I accelerate hard its much more noticeable. I have a 94 ex coupe. Any possible suggestions would be greatly appreciated.
Old Mar 23, 2003 | 05:28 AM
accord94's Avatar
Default Re: vibration in gas pedal (accord94)
i did a search and I couldn't find anything similar to this.
Old Mar 23, 2003 | 05:53 AM
NathanMorris's Avatar
check your nuts...lug nuts that is
Old Mar 23, 2003 | 07:32 AM
accord94's Avatar
Default Re: vibration in gas pedal (92Lx)
humor and advice, thats what I'm talkin bout
Old Mar 24, 2003 | 11:54 AM
accord94's Avatar
ok, I checked the lugs and they were all nice and tight. The vibration is still there. Any other ideas? I'm clueless at this point.
Old Mar 25, 2003 | 06:11 AM
accord94's Avatar
am I not giving enough info? Or is it just a dumb question?
It is more noticeable when going uphill
[Modified by accord94, 3:12 PM 3/25/2003]
Old Mar 25, 2003 | 09:19 AM
StimpyBoy's Avatar
Does it happen in Neutral? You said it usually only happens in 2nd gear, but has it ever occurred in neutral?
Try to duplicate the problem in neutral with a friend watching the throttle cable in the engine bay and see if anything unusual happens. Perhaps something is hopping around and tugging at the throttle cable???
Old Mar 25, 2003 | 09:52 AM
does ANYTHING else vibrate?
Old Mar 25, 2003 | 02:32 PM
Chiovnidca's Avatar
Bad inner c/v joints maybe?
Old Mar 25, 2003 | 04:21 PM
mwkirchner's Avatar
Default Re: vibration in gas pedal (TurboD16Chiovnidca)
This is what I was thinking. The inner CV joints will indeed give you a rumbling type of vibration under acceleration ... mostly. If the vibration is there when you are NOT moving ... then rule these out. The only thing that is strange to me ... unless I read it wrong ... is that it only happens in a certain gear at a certain RPM.
Old Mar 25, 2003 | 04:42 PM
accord94's Avatar
Default Re: vibration in gas pedal (mwkirchner)
ok so I took her out on the road and really concentrated so I could get the whole picture. The vibration is there under acceleration. Its most noticeable in 2nd gear around 2500rpm but its there in the other gears. Once I get up around 3k it smooths out. If its the cv joints then I'll be pissed cuz I just had the whole front axle assembly replaced not more than a month and a half ago. Can you replace just the cv assembly or am I correct in believing that thats part of the axle assembly. I just found my haynes manual and looked in the troubleshooting and lo and behold, it says bad cv joints is a possible cause of my problem. I might take it back to my mechanic.
Old Apr 4, 2003 | 06:06 PM
mwkirchner's Avatar
I am assuming that you probably had rebuilt axles installed. There is a possibility that one of the axles is bad.
You can indeed rebuild the inner joint on the axle ... it is NOT all one piece.
Old Apr 4, 2003 | 08:32 PM
accord94's Avatar
I took it in to my mechanic and he checked everything out. He found a bubble on my right rear tire and found that my front tires were mounted the wrong direction. I guess they can only spin one way. So he put the fronts on the back and a new tire and the other rear which was kinda new on the front. He couldn't find anything wrong with the axles. He's a real honest guy so I was looking in my haynes and it says that toe in can cause vibration in the drivetrain so I'm gonna have the allignment checked.
redlude97
Dec 30, 2004 07:06 PM
sshaikh01
Mar 2, 2003 08:37 AM
joeg26er
Feb 19, 2003 06:15 PM
Cat
Sep 30, 2002 06:48 AM
sa21199
Jan 4, 2002 03:25 PM
