replacing piston rings?
Old Mar 21, 2003 | 06:40 PM
91integraLSVTEC's Avatar
Default replacing piston rings?
i have total seal piston rings in my high comp ls/vtec, do you think its worth it replacing it with oem rings? i have a 12:1 ls/vtec and my compression right now is 180,190,200,220.. the motor only has about 2000+ miles.. i was wondering if it was worth replacing them and if so would i need new rod and main bearings?
tia
Old Mar 22, 2003 | 06:25 AM
Default Re: replacing piston rings? (91integraLSVTEC)
anybody??
Old Mar 22, 2003 | 08:21 AM
Chiovnidca's Avatar
tia
Why do you think they need to be replaced? Did you do a leakdown test?
Old Mar 22, 2003 | 10:08 AM
dwilson's Avatar
Default Re: replacing piston rings? (TurboD16Chiovnidca)
Are you burning any oil, any blue smoke?
Old Mar 22, 2003 | 11:57 AM
Kataku2K3's Avatar
Default Re: replacing piston rings? (dwilson)
What cams are you running??? I would definately leakdown the motor before you start pulling it apart.... High lift/duration cams will drop the overall dynamic compression therefore reading low on the PSI.... Peace
Old Mar 22, 2003 | 02:06 PM
Default Re: replacing piston rings? (Kataku2K3)
i heard total seal will rob hp, i'm not buring any oil i will do a leak down test soon but i'm pretty sure its the rings.. i'm running skunk stage 2 cams, ive heard others running similar setups and getting 300+psi across the board!! so do you guys think thats really low for that setup?
Old Mar 23, 2003 | 01:40 AM
Kataku2K3's Avatar
I doubt you have would 300+psi across the board running SK2st2 cams.... Your static compression would have very very high to achieve this... Those cams generate a lot of overlap which intern bleeds off cylinder pressure... Peace
Old Mar 26, 2003 | 05:54 AM
GM2000ITR's Avatar
New User
With 12:1 c.r., I'm sure 300psi is realistic. I'm hitting 270psi across the board w/ 11.5:1 c.r.
Old Mar 26, 2003 | 06:14 AM
sgT's Avatar
sgT
i get over 315 with toda C cams which have larger pri/sec lobes than skunk cams.
remember when doing a comp test its not in vtec
Old Mar 26, 2003 | 06:36 AM
GM2000ITR's Avatar
New User
Default Re: replacing piston rings? (sgT)
....and what was your c.r. SGT?....
Metal Head
Feb 19, 2009 08:37 PM
climb_on
16
Sep 5, 2007 08:49 PM
acman1
Jul 27, 2007 04:20 AM
Sketch_hs
May 12, 2005 06:44 PM
skunk2eg
Aug 17, 2004 12:10 PM
