Garett GT30 turbo, anyone running?
I heard lots of good things of it and it is worth the money, is is ballbearing too, what I want for even quicker spool. I am into the T04e .63 a/r but what exactly the difference between the 52 compressor trim and the 56 compressor trim. I know the 56 trim will give more lag and more top end, but it is a big difference and what would you do for AutoX boosting 0.45 Bar at those events. I need imediatly that amount of boost when I WOT at 5000 or above. Good with 56trim or better the 52?
I have now non ball bearing T3/T04e .63 a/r, .54 compressor stage 3 wheel. and I liked it with the log style DRAG manifold.
Setup: B18C6, cr 9:1, Haltech ECU, 3inch exhaust & dp, tubular manifold, daily boost = 1.2 Bar
btw: whats the diff between ceramic ball bearing and the Garetts new full steel ball bearing cartridge, not ceramic.....that sounds Ceramic is not that good. someone can explain me?!
[Modified by austrian type-R, 8:06 PM 3/21/2003]
Yes, the GT series of Garrett turbo's are FULL ball bearing center sections wich means instead of a single row of ball bearing(like normal ball bearing turbo's), there are dual ball bearings rows. The average seems to be that you can spool 600 rpm faster(or more) when compared to turbo's of the same size depending on your setup. The main benefit of this turbo is the fact that in between shifts, the turbo does not lose any velocity/spool whatsoever.
This is only a very simple explanation of this turbo. Hopefully someone else can elaborate if needed.
sorry i dont know the answer but, ever thought about higher compression piston??
relates to a helping for autox..
[Modified by Jordo, 4:05 PM 3/21/2003]
I have a GT25 (or GT28, different sites say different things)...geez i wish i had all the rest of the bits needed to bolt it on right now
GT25 is oil and water cooled, i'd assume all the GT series are like that
Another thing with the GT series turbo's is that you definitaly wanna run an inline oil filter. These turbo's will last forever, but It was HIGHLY recommended to use the filter because of the dual ball bearing cartridge.
let me get this straight, you wanna auto-X..... to4e .63 a/r, and quick spooling, thats wishful thinking imho., not flaming, just seems odd...... such a big turbo for .45 bar, 7-ish psi, i have a non BB t3t4, but i think BB is not the total cure for lag
im running the GT3040 on my h22a atm. The engine fully spools by 4,000 rpms but this is at only 10 psi. With WOT you should be able to spool it about 5k rpms if ur motor is a 1.8...
[Modified by austrian type-R, 8:19 AM 3/22/2003]
zulustypes
Jan 21, 2005 01:05 PM
ITRinEJ1
Aug 21, 2001 06:11 AM
