Just boosted my dx problems!!!!!!!
Old Mar 21, 2003 | 03:30 AM
Ty.'s Avatar
Ty.
Default Just boosted my dx problems!!!!!!!
Ok i put a turbo off a 92-95 si on my 99 dx hatch. i also put a 95 d16z6 intake manifold on it. It runs great but i just have my check engine light on. I need to get a missing link but when whe did the codes it came up with code 1 , then 41 then 65 what are these codes and what can i do to fix them besides the missing link. I just have one of my O2 sensors just chilling in my engine bay that could be something. Help me?????
Old Mar 21, 2003 | 04:43 AM
b16ahybrid's Avatar
Default Re: Just boosted my dx problems!!!!!!! (RiceRocketEK)
Well code 1 is oxegen content
and code 41 is oxegen sensor heater.Not sure what the other code is.
Hook the o2 sensor back up and if you don't already, get some check valves for the map sensor (temp fix until you get a missing link)
Old Mar 21, 2003 | 05:33 AM
Hybrid's Avatar
Default Re: Just boosted my dx problems!!!!!!! (b16ahybrid)
Well you put a manifold with obd1 sensors on a OBD2 ecu. Not sure if there will be a difference, maybe some one else can answer that.
I know an OBD2 GSR motor harness and sensors can plug right into an OBD1 ecu with no mods.
Why did you use a Z6 intake mani? Isn't your larger?
Old Mar 21, 2003 | 05:50 AM
Tinker219's Avatar
Default Re: Just boosted my dx problems!!!!!!! (Hybrid)
DX mani? no
Old Mar 21, 2003 | 06:18 AM
Tony Starks's Avatar
Default Re: Just boosted my dx problems!!!!!!! (Tinker219)
If you are using an OBD 2 ecu, maybe an o2 sim would clear it up.
[Modified by Tony Starks, 3:30 PM 3/21/2003]
Old Mar 21, 2003 | 09:17 PM
Ty.'s Avatar
Ty.
Default Re: Just boosted my dx problems!!!!!!! (Tony Starks)
Thanks for all the replys. I would plug in my other o2 sensor but i only have one spot to put one on the manifold and DX have 2 GAY o2 sensors. I put the d16z6 one on cause its all i could get in time its all port and polished so it is better than y8. What is a "o2 sim" tony starks. not to up on what that means.
Old Mar 21, 2003 | 09:26 PM
Racerage1's Avatar
o2 sim
o2 simulator...i dont know any place u can buy it though...
Old Mar 21, 2003 | 10:17 PM
tegasaurus's Avatar
Default Re: Just boosted my dx problems!!!!!!! (Racerage1)
o2 sim
http://userwww.sfsu.edu/~ecg/
-ryan
Old Mar 22, 2003 | 12:03 AM
DSC's Avatar
DSC
2nd o2 has to be in the cat.
Old Mar 22, 2003 | 02:31 AM
turbotec's Avatar
Default Re: Just boosted my dx problems!!!!!!! (DSC)
why not just drill a hole in the downpipe or after that, weld a nut to the pipe and stick the o2 sensor downstream somewhere. problem solved. might half to lengthen the wires a little bit but thats not hard
[Modified by turbotec, 11:31 AM 3/22/2003]
Old Mar 22, 2003 | 07:35 AM
CzanSOHC's Avatar
Default Re: Just boosted my dx problems!!!!!!! (turbotec)
thats all it takes.
Old Mar 22, 2003 | 09:36 AM
Ty.'s Avatar
Ty.
Default Re: Just boosted my dx problems!!!!!!! (CzanSOHC)
I thought about that.... by the way dsc i dont have a cat dx cats are in the header. I will have a nut welded in and see if that works THANKS. for all the help.
myessay
Apr 7, 2011 08:32 AM
JDM_EK3
Aug 5, 2005 10:30 AM
GSlowR
Dec 2, 2004 06:33 AM
NotPhilTran
Mar 26, 2004 07:48 PM
green91
Jan 27, 2004 07:31 PM
