is the b20a5 in the preludes an open or closed deck
Old Mar 20, 2003 | 11:27 PM
ryer_s's Avatar
Default is the b20a5 in the preludes an open or closed deck
hi i just wanted to know if the b20a5/a2 was an open or closed deck. and if its closed deck what is a amount of boost the block can handle. i dont care about rods or pistons i just want to know how much the block can handle. thanks
Old Mar 20, 2003 | 11:55 PM
MikeSarr_GSR's Avatar
Default Re: is the b20a5 in the preludes an open or closed deck (ryer_s)
I dont know what engine you are referring to. I had a 91 2.0si which was a B20a3 and the 2.0 "5" was the B21a1. They are an open deck setup and I would imagine with that cam profile you should be able to run a conservative 6-8lbs and get good gains from it I miss my 91 lude it was paid for if it were me, I would pull the motor, port the head, install ARP main cap and rod bolts, head studs and put in larger injectors. if you are boostin, it would be a good time to rebuild the motor and drop in some forged pistons.
[Modified by MikeSarr_GSR, 8:58 AM 3/21/2003]
Old Mar 21, 2003 | 12:42 AM
ryer_s's Avatar
Default Re: is the b20a5 in the preludes an open or closed deck (MikeSarr_GSR)
i have an 88 lx-i accord with an a20 in it. there is an b20a2 jdm engine swap that will slip right in with no problems. i can even use all but one motor mount. and the prelude b20a5 are the same motor but the only difference is that the prelude motor tilts back and the jdm accord b20a2 motor tilts forward in the bay. i was wondering how much boost the walls can handle. i was hopeing around 14 but guess not. thanks
Old Mar 21, 2003 | 05:21 AM
liquid51's Avatar
Tom at ludespeed hit around 11 lbs before his blew out. I think 9 could be safe on stock.
417greenmachine
Oct 12, 2015 09:53 PM
TravisBiggie
May 1, 2012 04:02 AM
goldsS2000
Honda S2000
11
May 21, 2010 08:55 AM
BWDOWN
Mar 23, 2010 11:52 AM
UserX826
Mar 9, 2009 04:38 AM
