what did i do wrong
Old Mar 20, 2003 | 07:06 PM
TruePlayaz114's Avatar
Default what did i do wrong
ok I just did a compression check on my car and it came out 210,200,200,190. Anyways when i put everything back and started the car it idled really rough. The car would shake and the motor sounded a lot louder. Does anyone know what i did wrong?
Old Mar 20, 2003 | 07:21 PM
dfoxengr's Avatar
Default Re: what did i do wrong (TruePlayaz114)
nope...bump for ur problem and those numbers sound way too high...
did you crank the motor manually when checking? or with the key?
you couldve flooded the cylinders if u didnt undo the neg. battery terminal if u did it with the key...
Old Mar 20, 2003 | 07:30 PM
Padawan's Avatar
Darth ModerVader
Did you replace all of the plug wires correctly?
Old Mar 20, 2003 | 07:54 PM
MattG's Avatar
New User
Plug wires are on the wrong plug
Something is loose.
Old Mar 21, 2003 | 06:49 AM
Default Re: what did i do wrong (MattG)
the motor is a 94 JDM b18c. I'm gonna check it again but how do i know which plug wires go where?
Old Mar 21, 2003 | 10:11 AM
i checked all the plugs and they're in the right place. But now that i think about it i did drop one of the spark plugs. Can that make a difference?
Old Mar 21, 2003 | 10:17 AM
sgT's Avatar
sgT
Default Re: what did i do wrong (hybridvteceg)
They sound about right to me.
Make sure you have everything plugged back in.
Check the gap on all of your plugs
Old Mar 21, 2003 | 10:43 AM
Default Re: what did i do wrong (sgT)
can i buy stock plugs in a discount auto. And which ones do i get and how much are they.
Old Mar 21, 2003 | 12:41 PM
dfoxengr's Avatar
i thought outer was supposed to be around 180-190 and inners 170-175..
Old Mar 21, 2003 | 12:45 PM
Pengo's Avatar
those numbers look ok to me
check the gap on that plug you dropped
Old Mar 21, 2003 | 12:53 PM
dfoxengr's Avatar
Default Re: what did i do wrong (Pengo)
hmm oh well..
coltonbarrier
Dec 4, 2013 12:55 PM
niterider96cord
Aug 14, 2012 05:08 PM
hatch808
Jul 14, 2004 03:08 AM
dizzyroc88
Feb 1, 2004 07:34 AM
Projekt20
Oct 11, 2002 10:24 PM
