Motor Mount Measurements
Old Mar 20, 2003 | 06:48 PM
Muckman's Avatar
Moderator in Chief
Default Motor Mount Measurements
What is the length of bolts #20 and 22?
Old Mar 21, 2003 | 04:32 AM
Muckman's Avatar
Moderator in Chief
Default Re: Motor Mount Measurements (Muckman)
Bump, need measurements to help complete gen2 project
Old Mar 21, 2003 | 06:02 AM
Muckman's Avatar
Moderator in Chief
I also need to know the lengths of A, B and C. My engine shop is welding the broken motor mounts on my project B18C1 and needs to put studs in.
Old Mar 21, 2003 | 07:53 AM
Muckman's Avatar
Moderator in Chief
come on tech guys. they cant fix my block without this information!
Old Mar 21, 2003 | 08:50 AM
dkim48's Avatar
Go to honda and ask to see the bolts. That would be your best bet. Good luck.
Old Mar 21, 2003 | 09:48 AM
Muckman's Avatar
Moderator in Chief
Default Re: Motor Mount Measurements (dkim48)
They're stupid. They pull the bolt sizes from the same place I am, it just lists a part number not dimenstion.
Old Mar 21, 2003 | 11:29 AM
shamoo's Avatar
Will you make something up for me please?
In Diagram C:
Bolt B is 12 x 1.25mm (43 ft-lbs)
Bolts C are 14 x 1.5mm (86.8 ft-lbs)
In Diagram B:
Bolts H are 12 x 1.25 mm (61 ft-lbs)
In Diagram A:
err...I'm not sure on this one. If you take a picture, I'm sure you can take it to Acura and they might be able to tell you.
I'm not entirely sure if this is the info you wanted. But hope it helped anyway.
Old Mar 21, 2003 | 12:24 PM
Muckman's Avatar
Moderator in Chief
Default Re: Motor Mount Measurements (shamoo)
In Diagram C:
In Diagram B:
Thank you but 12 and 14 is the head not the length.
Old Mar 21, 2003 | 12:52 PM
owen_the_soyboy's Avatar
got a wrench?
remove one at a time on your block, then measure them and the thickness of the bracket as well... one at a time will be okay.
I have them all laying around, I can measure them tomorrow if need be.
Old Mar 21, 2003 | 02:01 PM
dkim48's Avatar
Default Re: Motor Mount Measurements (owen_the_soyboy)
Why not just buy the damn bolts from honda??
Old Mar 21, 2003 | 04:42 PM
sackdz's Avatar
I will tell you what you need to know, but first I'll need to see some specs for this diagram:
Old Mar 22, 2003 | 08:11 AM
Muckman's Avatar
Moderator in Chief
Default Re: Motor Mount Measurements (sackdz)
I cant buy the bolts from acura the mounts on the block are broken, they have to be welded and a stud has to be inserted. the stud has to be roughly the same legnth as the original bolt.
Owen can I just come over to your house and get some rough measurements?
[Modified by Muckman, 12:22 PM 3/22/2003]
Old Mar 22, 2003 | 10:35 AM
Turbogixxer's Avatar
In Diagram C:
In Diagram B:
The 12 and 14 are the thickness of the bolt in mm and the 1.25 and 1.5 in the type of thread that the bolts, but he does says the how long they are.
Old Mar 22, 2003 | 10:36 AM
YAH,
azhfreak
Aug 27, 2018 11:21 AM
Slacker93eg
Aug 10, 2012 05:05 PM
lsvtek
Sep 29, 2008 11:45 PM
LSturboHB
Aug 29, 2002 03:52 AM
