Couple questions on my turbo install
I see where alot of people jb weld their return line into the pan. well I have an aluminum oil pan(2000 h22a4) and so I was unsure if I could do this as well with just jb weld...secondly if I have to weld it, I gotta find someone that can weld alum right??? Its not like steel or anything that is easier to weld.
Also I got a Greddy Type R BOV....how does that sound compared to the type S???
[Modified by slow94accord, 4:01 PM 3/20/2003]
it depends. first of all what kind of fitting will be welded to the oil pan. alluminum can be welded but if you have dissimilar metals there is a special process that needs to be done before welding wich can be expensive and hard to find. i had mine tig welded
mine is tig welded as well, please dont jb weld your return line.... i know some people have gotten away with it but personally i wouldnt trust it.
Well I've called 2 welders...both say i can't weld this SS fitting into my alum oil pan...I need an alum fitting!!! arrr...i dunno where to find this ****!!! arrrrrrr
tig weld-welding aluminum
I just had someone welded my charge pipe(alum)
it took like 1 hours to get it welded, but cant beat the hooded-up
killa price and good quality
