HELP!!!! need swap help asap ...
Old Mar 18, 2003 | 08:53 PM
prada_2o0o's Avatar
Default HELP!!!! need swap help asap ...
ive asked this and searched this question but no one has been able to answer it yet... i have a 97 civic coupe.. i put a 00 sir engine in ... and now im putting a d16y7 back into it... the d16y7 is a 96 .. and the harness behind the dash is from the 00 sir... how can i get the wiring right without pulling the dash again?? can i use the 99-00d16y7 engine harness and ecu ?? i have the 96 ecu.. but i am told it wont work with the 99-00 wiring.... i havent bought my engine harness yet because i need to know which one to go with for the least problems..
ur help is appreciated thanx
Old Mar 19, 2003 | 06:51 AM
Trey's Avatar
25 Year Member
Default Re: HELP!!!! need swap help asap ... (prada_2o0o)
The 99-00 D16 harness is the same as the 96-98 DX harness. Since you've swapped the interior harness to the 99-00 Si you are gonna have to swap the 96-98 interior harness back in to use the D16 swap. The 96 ecu wil lthen work with the 96-98 interior harness.
Good luck,
Old Mar 19, 2003 | 07:13 AM
EK22Tim's Avatar
Default Re: HELP!!!! need swap help asap ... (Trey)
Good luck,
Yup. I just went through a similar experience. I got a 96 EX harness for my 96 car, it turned out that someone redid the dash harness to 99-00 so I had to buy another 99-00 Si harness to install my H22!! Good luck.
Euro-R82005
Oct 15, 2015 05:43 AM
b20turbojason
Jun 8, 2009 04:30 PM
Timmay
Aug 15, 2005 03:59 PM
Silverbeast
May 14, 2003 11:07 AM
d0nkeyxPunch
Apr 16, 2003 08:18 AM
