Wheel balancing eights
Old Mar 18, 2003 | 11:46 AM
Ponch's Avatar
Default Wheel balancing eights
I have a 97 Civic HX with the stock rims. Is it possible to have them balanced with the weights placed on the back of the rim versus the front. It takes away from the looks. i know it's done on rims but i can't find anyone who does that. i'm in SC.
Old Mar 18, 2003 | 11:57 AM
Spade's Avatar
Default Re: Wheel balancing eights (Ponch)
Yes.
EDIT: Just tell your local shop to put them on the inside.
[Modified by Spade, 12:58 PM 3/18/2003]
Old Mar 18, 2003 | 02:14 PM
ThisLittleSleepeR's Avatar
Default Re: Wheel balancing eights (Spade)
i just got my weights put on the inside the other day. just tell the person putting them on.
Old Mar 18, 2003 | 02:52 PM
rastropovitch
Guest
Posts: n/a
Default Re: Wheel balancing eights (ThisLittleSleepeR)
Have them clean the area really well first, and it deos not hurt to put duct tape over the mounted weights
Schu
Old Mar 21, 2003 | 10:00 AM
Raven 69's Avatar
Default Re: Wheel balancing eights (MSchu)
What does the duct tape do??
Old Mar 21, 2003 | 11:40 AM
Vinny Chase's Avatar
yea, I work at discount tire and we do it all the time, just tell them you want your tires static balanced, and they will not put any weights on the outside
Old Mar 21, 2003 | 11:58 AM
94CivicSi's Avatar
Default Re: Wheel balancing eights (Vince10984)
Doesn't static balancing mean that your wheels and tires are balaned on a stationary bubble balance instead of a dynamic spin balancer?
To get the most accurate balance, you'll probably want to add weight to the inside and outside of the wheel. (ie. dual plane balancing). Have them use stick on weights instead of hammer ons. The stick ons can go just inside the wheel rather than on the lip. You won't even notice them.
Old Mar 21, 2003 | 12:47 PM
dfoxengr's Avatar
Default Re: Wheel balancing eights (94CivicSi)
static is inside only...
i work at a wheel shop and when theyre on the outside, theyre on the insode too, not just outside...just tell them to do bang-on static and theyll know what u mean. i would stick with bang-on weights with a stock wheel
MSchu
Jun 16, 2015 06:31 AM
Turbo-Si
Honda S2000
10
Oct 22, 2003 01:52 AM
sslude
Feb 1, 2003 02:22 PM
Dr Pooface
Jun 10, 2002 07:32 PM
