Weight of different flywheels
Old Mar 18, 2003 | 04:06 AM
Charlie Moua's Avatar
Default Weight of different flywheels
can anyone give me a list a weights for the flowing flywheels.
*jun
*toda
*stock ITR
*clutch masters
please feel free to ad others to the list to.
Old Mar 18, 2003 | 05:19 AM
AssPenny's Avatar
Default Re: Weight of different flywheels (Charlie Moua)
ACT xact superlite cromoly is 8.8lbs
Old Mar 18, 2003 | 05:52 AM
Default Re: Weight of different flywheels (AssPenny)
ya know what... i never even hear about many people running thoes... how do you like it?
Old Mar 18, 2003 | 06:05 AM
AssPenny's Avatar
I'll let u know in about 2 weeks when I install it.
Old Mar 18, 2003 | 09:09 AM
Padawan's Avatar
Darth ModerVader
*JUN - 4.3 / 4.6 kg (9.46 /10.12 lb.)
*Toda - 4.1 kg (9.02 lb.)
*stock ITR - ~15 lb.
*CM/Fidanza - 7.5 lb.
Old Mar 18, 2003 | 09:12 AM
Eva01's Avatar
Default Re: Weight of different flywheels (Padawan)
Comptech Chromoly=8.75lbs
Old Mar 18, 2003 | 09:13 AM
RTW DC2R's Avatar
Default Re: Weight of different flywheels (Eva01)
CM
Old Mar 18, 2003 | 09:22 AM
FAST4DR's Avatar
Default Re: Weight of different flywheels (RTW DC2)
Dont just consider the weight. You need to take into consideration the rotational mass - if flywheel x weighs 9 lbs but retains 65% of its mass at its hub, it will spin faster than flywheel y which might weigh less, but with worse weight distribution.
Old Mar 18, 2003 | 09:53 AM
Willard's Avatar
Default Re: Weight of different flywheels (FAST4DR)
don't bother Dave... everyone knows that the total weight is the MOST important thing when looking to buy a flywheel.
Old Mar 18, 2003 | 09:58 AM
FAST4DR's Avatar
Default Re: Weight of different flywheels (Willard)
Sorry...I forgot. Damn this new medication.....!
Old Mar 18, 2003 | 10:37 AM
Padawan's Avatar
Darth ModerVader
Good point Dave, but the problem is that weight distribution data is much more difficult to obtain than simple weight figures. I think when it comes down to it though, most people base their decision not only on weight, but on price, personal material preference (i.e. chromoly, aluminum), starter compatablity, and for some, brand name, as well. Obviouisly, some individuals will place more emphasis on certian atributes than others.
Old Mar 18, 2003 | 10:44 AM
Stinkycheezmonky's Avatar
Suspetise...
I'm curious, what exactly are the differences between chromoly and aluminum as far as flywheels are concerned? Is chromoly stronger than aluminum? Can one or both be resurfaced? I'm assuming chromoly is more expensive than aluminum, but I'm just basing that on the prices of what I think are available (ex. Toda more expensive than Jackson Racing).
Old Mar 18, 2003 | 04:17 PM
[QUOTE]*JUN - 4.3 / 4.6 kg (9.46 /10.12 lb.)
*CM/Fidanza - 7.5 lb.[/QUOTE
anyone know the stock weight if the B16 and B18B flywheel? just need to compare it alittle.
Old Mar 18, 2003 | 04:25 PM
Big Phat R's Avatar
I have the Spoon flywheel.
4.2 kg = 9.24 lbs
"For the ultimate in street and strip performance, choose the Spoon Sports Lightweight Flywheel. Weighing in at 4.2kg compared to the factory 6.9kg. This flywheel is not TOO light, so you won't loose off the line torque. Help your engine spin freely while making power with one of these Spoon flywheels. Already pre-balanced and comes with a new pilot bearing and flywheel bolts...simply the BEST. Will fit all B-series transmissions, cable and hydraulic. "
Old Mar 18, 2003 | 05:42 PM
lilcasino's Avatar
I have a Comptech Aluminum Flywheel under 7lbs
Old Mar 18, 2003 | 05:45 PM
migs's Avatar
Default Re: Weight of different flywheels (lilcasino)
96 spec JDM ITR flyhwheel = 13lbs
Old Mar 18, 2003 | 05:59 PM
CunninLynguist's Avatar
Default Re: Weight of different flywheels (Migs)
chromoly vs aluminum
I would also like some futher insite on the comparision.
spoondek
17
Nov 18, 2003 09:49 AM
rated_r
Nov 25, 2002 05:01 AM
Spoold_R
Jan 1, 2002 07:54 AM
Rodney
Aug 16, 2001 05:58 PM
Rodney
Jul 23, 2001 11:43 PM
