would a 86-89 integra tranny bolt on to d16a6?
well im tryin to drop a single zc into a 86 hb. mmmmmm how positive are u? and does the 89 integra uses a mid shaft??
Guest
Posts: n/a
oh, if it's going into an 86, then it should work perfectly. the tranny will bolt into that body.
as for the mid-shaft, i'm not sure...
don't quote me on anything though, never tried it to know 100%
I don't think you can do a sohc zc because I think the trans mounts bellhousing is different from the motor and the drivers side mount is on the side where you would need to mount in front of the motor. I know you can do a dohc zc from the 86-87 integra from japan and that bolts in. if you do this I am thinking of trying to switch to a sohc head for more camshaft variations and cheaper parts.
well about the motor mount on the front i can use the stock 86 mount. so wuts the color of the top for the 86-87 jdm zc? i dont think its the black 1 then.
http://www.geocities.com/crx1stgen/1stGenHybrid.txt
he talks about the swap in that article but then he later says that he hasnt done it himslef. so
how sure are u about the diff of the hosings bettween the 86-89 tranny and the sohc block??
Blind-Fashion
Dec 17, 2003 08:44 PM
