HELP...blaupunkt headunit problem..wont play sound
Old Mar 17, 2003 | 09:48 AM
dfoxengr's Avatar
Default HELP...blaupunkt headunit problem..wont play sound
hooked it up properly, everything works, all functions and all, my friend tested one speaker before we finished and it worked, then when we connected the other one...(only 2 for now Infinity kappa 6.3.5 the newer ones..i have 2 more in my room, lol...) it doesnt play anymore sound at all i checked all the fuses, but maybe a ground or power output could be wrong ???please help..
Old Mar 17, 2003 | 05:41 PM
dfoxengr's Avatar
Default Re: HELP...blaupunkt headunit problem..wont play sound (hybridvteceg)
help!!!
Old Mar 18, 2003 | 05:17 PM
JOMO
Guest
Posts: n/a
lol, it sounds like some wires arent connected right, smell anything burning maybe?
Old Mar 18, 2003 | 07:37 PM
dfoxengr's Avatar
Default Re: HELP...blaupunkt headunit problem..wont play sound (JOMO)
no its hooked up fine..nothing burnt, ust dont know what to do...?
Old Mar 18, 2003 | 07:56 PM
koco's Avatar
Check the radio's balance and fader settings.
Old Mar 18, 2003 | 08:06 PM
dfoxengr's Avatar
Default Re: HELP...blaupunkt headunit problem..wont play sound (koco)
yeah tried that...
does anyone have experience with this headunit or Blaupunkt in general setting the power distribution to each speaker? the manual blows...
Old Mar 27, 2003 | 02:43 PM
dfoxengr's Avatar
anyone with help, any grounds that could be making the sound only not work?
Old Mar 29, 2003 | 08:14 PM
dfoxengr's Avatar
Old Mar 30, 2003 | 01:27 PM
dfoxengr's Avatar
anyone?
Old Mar 30, 2003 | 04:26 PM
rjr162's Avatar
my guess is one of your connections to your speakers are shorting to ground (IE> the connector on the speaker is touching something metal) or something of that nature. Rather odd in that car to be touching metal, but that would shut it down.
Old Mar 30, 2003 | 05:18 PM
dfoxengr's Avatar
Default Re: HELP...blaupunkt headunit problem..wont play sound (rjr162)
can t be because i hooked up another speaker that wasnt even installed in the door to it and it didnt work either..? BTW one of the speakers worked for a minute, when we were putting it in, then when we hooked the second one up, it stopped.
Old Mar 30, 2003 | 05:48 PM
rjr162's Avatar
heh take a pic... it's really hard without being able to see. It sounds almost as if the speakers are hooked together like a common ground between them... which would cause this type problem. THat or a speaker shorting out, a speaker line, maybe when you push it in the harness is getting bent too far, etc.
Old Mar 30, 2003 | 05:50 PM
dfoxengr's Avatar
whats to take a pic of...that cannot possibly help... we straight hooked an uninstalled speaker hardwired to the harness...and only one, so there couldnt be 2 speakers grounding eachother...hmm, this is making me so mad that i have no music...dammit
Old Mar 30, 2003 | 05:52 PM
rjr162's Avatar
i don't have a clue w/o being able to go there and meter and trace everything etc...
Old Apr 2, 2003 | 05:51 PM
dfoxengr's Avatar
damn neone else?
Old Apr 3, 2003 | 11:23 PM
jonnybravo's Avatar
When you connected the extra speaker from outside the car, did you disconnect the other speakers(that are in the car) because it still won't play if it is grounding.
When you turn the accesory off and then on, do you hear a very soft an subtle pop from either speaker? If so, that speaker is grounding. Also you can check the impedence from the speaker at the deck to see if they or the wires are good.
Old Apr 4, 2003 | 10:25 AM
dfoxengr's Avatar
Default Re: HELP...blaupunkt headunit problem..wont play sound (jonnybravo)
i disconnected the other speakers, no pop, and ill check the power...thanks..neone else
Old Apr 5, 2003 | 07:57 PM
dfoxengr's Avatar
Old Apr 7, 2003 | 04:38 PM
dfoxengr's Avatar
ahhhh...help
Old Apr 8, 2003 | 08:29 AM
dfoxengr's Avatar
anyone?
Old Apr 8, 2003 | 06:20 PM
CustomCJ00's Avatar
1st what kind of car/year?
is the radio actually on and u just dont have any sound?
if so past posts are probably correct
pull the radio out of the dash and disconnect all speakers
turn radio on and take a speaker (one that is not installed in your car) and hook it up to one channel of your radio at a time.
if you now get music from the test speaker then you do have something shorted to ground on the old speakers.
reconnect one speaker at a time until the radio shuts off again and u will know which speaker is causing the problem
Old Apr 8, 2003 | 06:24 PM
dfoxengr's Avatar
Default Re: HELP...blaupunkt headunit problem..wont play sound (CustomCJ00)
92 civic hatch
radio is on and no sound
its already out of the car
ill try again though...this sux
Old Apr 9, 2003 | 09:08 AM
dfoxengr's Avatar
top
turbo99
Audio / Security / Video
14
Apr 28, 2006 08:55 AM
T_bones
15
Feb 1, 2006 08:09 AM
scrambledeg
10
Dec 9, 2003 07:12 PM
ravi
10
Jun 7, 2003 11:34 PM
95IntegraGSRAZ
Jun 11, 2002 07:48 PM
