Thumping noise Please Help
Old Dec 4, 2003 | 05:30 PM
scrambledeg's Avatar
Default Thumping noise Please Help
Can any one help? I have a punch 240 and all of a sudden my sub started making a thumpin sound. I checked the ground and everything seems kewl. has anyone had this problem b4. I dont know to much about amps and stereos. Ireally dont want to buy another amp if this is something that can be fixed.
Old Dec 4, 2003 | 06:02 PM
brads94accord's Avatar
does it happen when you turn your radio on and off? when you change stations? when does it happen?
is it a constant?
aftermarket headunit? or factory? give us some more info about it. is it hooked up through a rca line in converter?
did you install it?
Old Dec 4, 2003 | 06:20 PM
Default Re: (brads94accord)
its constant but it would also do it when i turned off my stereo.
Old Dec 4, 2003 | 06:23 PM
shibby's Avatar
Default Re: (towcivic)
re check your ground. make sure it is as tight as you can possibly get it. if it moves around its gonna make some noise. make sure all your connections are tight and nothin is like barely hangin on.
are your power wires and rca's next to each other?
Old Dec 4, 2003 | 06:24 PM
the deck is a sony explode and the amp is hooked up via rca no inline converter. And yes i hooked it up but have never had any problems. Do amps just give out over time?
Old Dec 4, 2003 | 06:27 PM
Default Re: (shibby)
Its been so long since ive looked but i think that the rca are seperate from the power but ill have to double check. and the ground is tight and its on bare metal.
Old Dec 4, 2003 | 06:35 PM
well i we had that problem when me and my g/f's dad were hooking up her system but it ended up being the line in converter we were using, but thats not the case in your situation. i would just check all your connections. pull your head unit out and check all your connections on your rcas make sure they are plugged it tight. and possibly re ground it somewhere else and shorten your ground wire a little bit if possible.
and when you have your headunit out make sure all speaker wire connections are tight.
Old Dec 5, 2003 | 08:14 PM
thx 4 ur help ill see what i can do
Old Dec 6, 2003 | 12:15 PM
HNDAPWR's Avatar
your amp is toast
Old Dec 7, 2003 | 08:56 PM
skunksol's Avatar
Default Re: (HNDAPWR)
from experience most of the time when I have a problem like that it turns out to be in the head unit. It's giving a signal to the amp to make the speaker do that. Amps are stupid and just do what they're told to do. you might try running an external audio source...like a boom box with rca preouts. If it stops with the external source you'll know it's the head unit or an rca problem
Old Dec 9, 2003 | 07:12 PM
Default Re: (skunksol)
thx Ill try that
zsudz922
Audio / Security / Video
10
Aug 1, 2007 04:20 PM
jojo006
Sep 13, 2005 09:16 AM
Andres-eh2
11
Jul 9, 2005 08:46 AM
LaOstha
Mar 2, 2005 05:15 PM
shattergsr
Jun 12, 2002 06:24 PM
