Sub/Speakers problem
Old May 29, 2003 | 02:14 PM
ravi's Avatar
Default Sub/Speakers problem
well today i noticed that there was a humming sound coming from the sub and when i disconnected the sub there was very very slight humming coming from the oem speakrs. And when im listening to music sometimes the bass decreases and then increases as if its not balanced...i checked the RCA wires and checked the wires behind the deck ..if i move them i can hear the humming getting louder sometimes...i checked all the wires they seem fine...now i dont know what to do
any help would be great
thanks
Old May 29, 2003 | 02:39 PM
adrian1281's Avatar
Default Re: Sub/Speakers problem (ravi)
bad ground maybe....
Old May 29, 2003 | 02:49 PM
ravi's Avatar
Default Re: Sub/Speakers problem (sparky69)
checked all the grounds there fine
Old May 29, 2003 | 02:53 PM
nsxxtreme's Avatar
Well if you move the wires and the humming gets louder that should cause a big light bulb to go off in your head. There is something wrong with you wireing. Try changing out the RCA's. Also verify you have a good ground at the deck.
Old May 29, 2003 | 03:35 PM
ravi's Avatar
Default Re: Sub/Speakers problem (nsxxtreme)
yea thats what i thought but the wires all seem fine..everything is covered with electrical tape...even weirder now when i accelerate i can hear the humming noise in my sub...kinda sounds like a exhaust now..exhuast sound coming from the sub when i accelerate
Old May 29, 2003 | 08:13 PM
darkvibe's Avatar
Maybe it's interference? Does it whine like alternator noise?
Old May 29, 2003 | 08:37 PM
ravi's Avatar
Default Re: (darkvibe)
it doesnt whine it hums i checked all of the grounds and they seem fine to me..im totally out of ideas and have no idea what it can be
Old May 30, 2003 | 09:10 PM
ravi's Avatar
Default Re:
basically re wired all the wires on the harness...jus the main ones..ground, power, remote, etc...and still same thing. I even made a new remote wire to connect to the amp and same thing..new rcas..same thing
and all the ground are perfectly fine no problems....and i can hear noise when i rev the engine..sounds like a exhaust...
what could be the problem?
would loose speaker wires cause this noise?..cuz i did not check those...and i know for a fact its coming from behind the deck..cuz if i fiddle around with the wires back there the sound either gets louder or quieter...
Old Jun 7, 2003 | 08:59 PM
darkvibe's Avatar
Is there a power wire laying on or close to the speaker wire?
that'll do it, just like if a power wire is run with an RCA cable.
Old Jun 7, 2003 | 11:26 PM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkvibe &raquo;</TD></TR><TR><TD CLASS="quote">Is there a power wire laying on or close to the speaker wire?
that'll do it, just like if a power wire is run with an RCA cable.</TD></TR></TABLE>
That was my thought, if on installation the power wire was run along the same side of the car as the RCA's.
Old Jun 7, 2003 | 11:34 PM
ravi's Avatar
Default Re: (SoCal ITR)
the power wire is completly seperate from any other wiring...rcas are seperate...the other wiring that is close to each other is the remote wire and power wire but i doubt that would cause any trouble.....otherwise i cant think of anythin else...checked all grounds..tried different grounds but same thing....i think i'll go get me one of those ground isolators for my rcas...hopefgully that helps
@5200
Audio / Security / Video
Mar 18, 2009 08:15 PM
accordaffair
Sep 2, 2008 05:47 PM
kon
Mar 3, 2007 02:38 PM
turbo99
14
Apr 28, 2006 08:55 AM
blk97lude
Jul 31, 2003 04:14 AM
