cam gear question
Old Mar 16, 2003 | 03:22 PM
cleantegra's Avatar
Default cam gear question
i need some info on cam gears-- will a adj cam gear off a 96-00ex fit the 92-95 ex engines. thx for the help
Old Mar 16, 2003 | 04:15 PM
cjames235's Avatar
Default Re: cam gear question (Ex-DSM'er)
yes it will fit but they are 5 degrees off from each other.
Old Mar 21, 2003 | 05:00 PM
cleantegra's Avatar
Default Re: cam gear question (cjames235)
so is the degrees off in advance or retard??---and will this mess up my timing if i were to replace the timing belt
Old Mar 21, 2003 | 05:18 PM
kommon_sense's Avatar
My understanding was that the cam gears are the same from 88-00. The 5-6deg difference between the 92-95 and 96-00 is in the cam itself. So swapping the cam gear is fine. However if you swap the camshaft itself, then you have to adjust for the difference.
Old Mar 22, 2003 | 07:20 AM
cleantegra's Avatar
Default Re: cam gear question (kommon_sense)
thanks , its just that i had a p&p head put in with a zex cam and skunk2 cam gear and my engine is reading compression of 110 115 105 110--so the timing is probabaly off
Old Mar 22, 2003 | 07:39 AM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
those numbers seem low for a compression test did u do the test right. what i mean is did u have your foot on the gas while u were cold cranking it
Old Mar 23, 2003 | 11:52 AM
cleantegra's Avatar
Default Re: cam gear question (streetdreams02)
i actually had another mechanic look at my car the throttle was wide open--they also advanced the cam gear 2 degrees and compression was up to 150 in all cylinders--they tell me the timing is off a tooth--back to the original mechanic i go
Old Mar 25, 2003 | 07:52 AM
cjames235's Avatar
the 88-95 cam gear is the same, but the 96-00 is 5 degrees(or about a half-tooth) off, which is the reason you have to use a z6 cam gear to put a z6 cam in a y8.
this is a cam gear for a y8 notice the UP mark is between two teeth(red arrow). on a z6 cam gear the UP mark is in the middle of the actual tooth (blue line). notice how the gear is advanced 5 deg. to match up to the z6 Up mark.
Igaly
Honda Civic (2001 - 2005)
11
Feb 15, 2009 06:40 AM
nutball72
Aug 21, 2006 01:47 PM
igo4bmx
Sep 13, 2005 01:53 PM
mrnice1058
Nov 8, 2004 03:34 AM
Black96Cobra
Oct 28, 2001 11:06 PM
