dependable turboed crx??
I am thinking of building a stock crx si motor then turbo charging it. What would i need to do to in order make the car dependable without a fuel management system? I want everything else except spending a grand on a fuel management. Anyone have any ideas? What injectors? from what? size? manifold? downpipe? BOV? oil cooler? clutch? runnin about 6-10 lbs.? rubber(tires)? any turbo xs stuff?
Thanks,
Matt
Thanks,
Matt
go do searchs on the Force induction forum
u get better responses
but unless u wanna get a already build turbo kit.....
if u going home made
Vortech FMU 12:1
MSD 6A BTM
with a Zdyne Gold u can run 450cc injectors
on a A6 i wouldnt boost any more than 7 psi max on daily driven basis
HF or STD manifold
stuff like this are the bassis for a home made turbo.....
more details can be found on the FI forum'
Vortech FMU 12:1
MSD 6A BTM
HF or STD manifold
Check out GhettoDyne.com. They have reverse engineered the PM6 ECU so that it can be controlled and programmed by laptop and are about to add boost control features. Once that is done, it will basically be a free Hondata system.
nyspecialist
14
Apr 8, 2006 06:02 PM
