Is it my alternator?
Old Mar 15, 2003 | 07:37 AM
KEVlN's Avatar
New User
Default Is it my alternator?
I posted this in the tech forum, but I also wanted to see if I could get some help in here. As I was driving tonight, my car started to loose power, and my lights started to dim. Eventually my car stopped working. I went to try and start it back up and nothing. I let it sit for about 20 minutes and it started back up, but after driving, the same thing would happen and my car would eventually die again. I recentely put a new alternator belt on. It seems really tight. Could this have any affect, or is my alternator completely dead? Is my belt too tight, or does this have nothing to do with it? My battery light also came on. Thanks in advance.
-kev
Old Mar 15, 2003 | 07:39 AM
thaiphob's Avatar
Nikon!!!
Default Re: Is it my alternator? (B8TeenRex)
have you changed your altenator at all? is the battery you have a new one? i had the same problem with my crx and it was a bad altenator. you can bring it by a checkers or auto zone and they can check it for you for FREE!
Old Mar 15, 2003 | 07:53 AM
KEVlN's Avatar
New User
Default Re: Is it my alternator? (thaiphob)
Yeah I was thinking about doing that today. The battery is less than a year old. How hard is it to change an alternator? I have never done it before. And also, would autozone have an alternator in stock, or should I order threw Honda. I really don't have another car, so I need to get this done ASAP.
Old Mar 15, 2003 | 08:28 AM
Kato7997's Avatar
Got my alt at autozone for $90 after core refund. Installation isn't too difficult...Do a search and you'll find alot of info. There are several ways to do it...I used the 'loosen the master cylinder' technique...
Old Mar 15, 2003 | 08:38 AM
KEVlN's Avatar
New User
Default Re: Is it my alternator? (Kato7997)
Yeah I just did a search. I have the B18 in my crx, and in the searches it tells me that integra owners must remove the left side axle for removal of the alternator. Will I have to do the same thing in my crx, or will there be enough clearance?
[Modified by B8TeenRex, 11:39 AM 3/15/2003]
Old Mar 15, 2003 | 09:28 AM
Creamies's Avatar
check out my alternator woes, hopefully it will help.
https://honda-tech.com/zerothread?id=417817
Old Mar 15, 2003 | 10:01 AM
KEVlN's Avatar
New User
Default Re: Is it my alternator? (Creamies)
Thanks for the help. I just hope it is my alternator. I don't want to buy a new one, put it on, and then run into the same problem. But I am pretty sure that's what it is.
Old Mar 15, 2003 | 12:27 PM
Flexmyrex's Avatar
reply
unbolt the master cylinder and you;ll have enough clearance
worked for me w my ls
wspencer5
Honda Civic (2001 - 2005)
Jan 3, 2015 02:10 PM
BoltonGSR
Jul 7, 2008 08:27 PM
Slammed Ek9
May 2, 2005 12:06 PM
ch4nq
Jul 20, 2004 07:02 PM
KEVlN
Mar 15, 2003 10:07 PM
