15 psi daily tuned???
does this seem alil unreasonable ive searched and searched and see ppl running 12psi tuned on stock internals it seems to make sense that i could run 15 psi daily tuned with the following mods b18b,ross pistons(8.5),eagle h beam rods, str blockguard,jg head,ferra valves,crower springs & retainers,crower 403 cams,skunk2 cam gears,skunk2 IM,bbk 70mm tb, aem rail & regulator,aem pullies,aem ems,act extreme clutch,act prolite flywheel,mount inserts,msd ing box,cap,coil,holley 525cc injectors and revhard 2 turbo kit.
thanks
Gary
thanks
Gary
Nice setup, should be able to run 15psi easy. I'd suggest bumping the compression up to atleast 9.0:1 and there is no need for a blockguard. For the money invested in this engine you might as well get it sleeved. also what trim turbo do you plan on running?
Yea you can run 15 psi on stock internals. My bro did in his teg w/ a drag 3 kit, walbro 255HP intank fuel pump, 440's, aem fuel rail, and some other stuff w/ an AEM ems. He ran like that for 1/2 a year, until he fucked up one of his ringlands on one of his pistons. Everything was tuned correctly, but that was the limit of stock internals.
GL though. I surely wouldnt do it for a daily driven car, but occassionaly I would. It all depends what your goals are.
TurboB18C1
Jul 7, 2004 02:27 PM
