15 psi daily tuned???
does this seem alil unreasonable ive searched and searched and see ppl running 12psi tuned on stock internals it seems to make sense that i could run 15 psi daily tuned with the following mods b18b,ross pistons(8.5),eagle h beam rods, str blockguard,jg head,ferra valves,crower springs & retainers,crower 403 cams,skunk2 cam gears,skunk2 IM,bbk 70mm tb, aem rail & regulator,aem pullies,aem ems,act extreme clutch,act prolite flywheel,mount inserts,msd ing box,cap,coil,holley 525cc injectors and revhard 2 turbo kit.
thanks
Gary
thanks
Gary
Re: 15 psi daily tuned??? (zexteg)
the skunk2 manifold wont accept a 70mm tb without modification.
what will you control those injectors with?
EDIT: ahh, i found the ems in that long run on
Nice setup, should be able to run 15psi easy. I'd suggest bumping the compression up to atleast 9.0:1 and there is no need for a blockguard. For the money invested in this engine you might as well get it sleeved. also what trim turbo do you plan on running?
Re: 15 psi daily tuned??? (@irborne)
Yea you can run 15 psi on stock internals. My bro did in his teg w/ a drag 3 kit, walbro 255HP intank fuel pump, 440's, aem fuel rail, and some other stuff w/ an AEM ems. He ran like that for 1/2 a year, until he fucked up one of his ringlands on one of his pistons. Everything was tuned correctly, but that was the limit of stock internals.
GL though. I surely wouldnt do it for a daily driven car, but occassionaly I would. It all depends what your goals are.
TurboB18C1
07-07-2004 02:27 PM
