no spark
check the resistance between the coil tower and the positive coil terminal. if you get no resistance then the coil is dead. if you do get reisistance then the ignitor is probably bad. those are the 2 common problems with accords.
i know that the ignitor is not bad cause it tries to crank over but theres not enough spark to crank over.i changed the ignition module and nothing so im guessin its the distrubutor
the reason i say that theres no spark is because i pulled out one the plug wires out and put a screw driver to it. i tried to crank it over and no kind of spark so im guessing its the distubutor.
just one wire or all of them? if it's all of them, then replace the dist. if it's just one wire, then replace the wires.
vtec.dc2
Jan 20, 2006 04:49 PM
s2kkk
20
Apr 15, 2004 11:12 AM
