turbo pipe questions for CRX
Old Mar 11, 2003 | 09:33 PM
kHoA DoGG's Avatar
Default turbo pipe questions for CRX pic request
Since the 1st gen DSM 'pipes' seem flexible. Can I use those style hoses for my piping.
[Modified by sNoOziN' EF8, 3:38 PM 3/12/2003]
Old Mar 12, 2003 | 12:19 AM
kHoA DoGG's Avatar
Default Re: turbo pipe questions for CRX (sNoOziN' EF8)
ttt
Old Mar 12, 2003 | 06:44 AM
rioninja's Avatar
Yeah you sure can. A buddy of mine uses dsm piping on his junkyard setup.
Old Mar 12, 2003 | 06:50 AM
kHoA DoGG's Avatar
Default Re: turbo pipe questions for CRX (rioninja)
Hey does your buddy have any pics of it? So I can see which pipes I can reuse and which I can't.
Old Mar 12, 2003 | 08:45 AM
Lord Quaalard's Avatar
You might be able to modify that CAI you have in your sig for part of the piping, just a thought.
Old Mar 12, 2003 | 09:47 AM
kHoA DoGG's Avatar
Default Re: turbo pipe questions for CRX (Lord Quaalard)
Good looking out, do you mean the upper part of the lower part? I have a bypass in between and plan on running a bov w/ an 45 degree charge pipe. Will AEM pipes handle low boost?
Old Mar 12, 2003 | 09:52 AM
turbod16y8's Avatar
i used my aem cai for the charge pipe and i got an adapter at autozone from 2/14 to 1 7/8 i think, to fit the dsm bov piping. then use the rubber hoses on the dsm to route it to the intercooler.
Old Mar 12, 2003 | 09:58 AM
I'm trying to piece together a kit myself and have this exact intake. I was planning on using it as the after intercooler piping. For yours, you could replace the bypass valve with a rubber coupling. Or you could do what I'm going to do and mount a DSM BOV in between the upper and lower tubes with some couplings (the BOV is still attached to the stock tube). That way you only have fabricate the before intercooler piping. Depending on here you are mounting your intercoooler, it should work like a champ.
And don't worry about the intake tube failing because of pressure. That small diameter of pipe will take a lot more than any turbo can dish out. Trust me, I'm a pipeline engineer.
[Modified by Lord Quaalard, 12:59 PM 3/12/2003]
Old Mar 12, 2003 | 02:38 PM
kHoA DoGG's Avatar
Default Re: turbo pipe questions for CRX (Lord Quaalard) pic request
Any body got pics?
Old Mar 12, 2003 | 02:49 PM
Brad's Avatar
Default Re: turbo pipe questions for CRX (Lord Quaalard) pic request (sNoOziN' EF8)
After the aem it goes to half of a u bend and the bov is mounted to that. From there it goes to a dsm ic. I don't have any pics of the bottom part though.
Old Mar 12, 2003 | 06:14 PM
kHoA DoGG's Avatar
Default Re: turbo pipe questions for CRX (Brad)
thanks, i see now. why is the wastegate hooked up to the charge pipe? that red hose that is.
Old Mar 12, 2003 | 06:19 PM
Brad's Avatar
There's no nipple on the turbo for the wg line, and since it was an available hole I made use of it.
Old Mar 12, 2003 | 07:58 PM
kHoA DoGG's Avatar
turbo's need wastegate nipples?
Old Mar 12, 2003 | 08:12 PM
Speed PHreak's Avatar
There is normally a port/nipple on the compressor of the turbo for the wastegate signal. The wastegate needs a boost signal from SOME source to open, else it'll stay closed all the time.
Old Mar 12, 2003 | 09:51 PM
r7's Avatar
r7
hey brad, what did you do with ur rad fan?
Old Mar 12, 2003 | 10:23 PM
Brad's Avatar
Default Re: turbo pipe questions for CRX (r7)
I used a hayden fan mounted on the other side. I forget the size, but it was a perfect fit.
Old Mar 13, 2003 | 04:28 PM
r7's Avatar
r7
where do u get one? how $?
Old Mar 13, 2003 | 04:37 PM
UberTeg's Avatar
Default Re: turbo pipe questions for CRX (turbod16y8)
Holy ****, what an adapter..... 1/7" to 1 7/8"!
Old Mar 13, 2003 | 04:44 PM
Brad's Avatar
I got mine from a local independent auto parts store, but you can get them at pep boys.. I don't remember the price.
Old Mar 14, 2003 | 10:28 AM
r7's Avatar
r7
hm, don't have those stores here, i'll try and find one locally. thanks
nabs.no.abs
Jul 8, 2008 04:52 PM
Soon_2b_evil
Jun 21, 2004 11:33 AM
AirWaveGT
Mar 28, 2004 08:41 PM
navz121
Dec 20, 2003 12:42 AM
jthelman
Feb 15, 2003 11:32 PM
