7000 rpm and cut why??
Old Mar 11, 2003 | 10:33 AM
_VTI-R_'s Avatar
Default 7000 rpm and cut why??
hi
y have make may own turbo kit and i put a missing link
now and i run i cut at 7000 rpm ( before i cut at 8500rpm )
my engine is B16 A2 on civic
please tell me if you know whats happen
Old Mar 11, 2003 | 11:41 AM
ninesecrx's Avatar
Default Re: 7000 rpm and cut why?? (_VTI-R_)
Maybe your knock sensor isnt working on the wire went bad?
Old Mar 11, 2003 | 01:10 PM
Drag_Dc2's Avatar
Default Re: 7000 rpm and cut why?? (ninesecrx)
I dunno if this might be relevant,
I was recently faced with a similar scenario the car would just bog at 7k. However I believe it was due to my ignition arching out. While driving the car NA i did not experience this problem. However, shooting N20 the car just bogged. In addition I noticed a great deal of electrical shock.
If you have an upgraded ignition this could be a problem as the spark isnt strong enough due to the arc.
Just a thought,
Eric
Old Mar 11, 2003 | 02:10 PM
madman604's Avatar
Default Re: 7000 rpm and cut why?? (DragEg)
tried a smaller spark plug gap?
Old Mar 11, 2003 | 02:21 PM
simike's Avatar
Default Re: 7000 rpm and cut why?? (Turbo E)
When i went turbo i had the same problem. I changed my plugs and that didn't help, so i thought for sure it was the ignition. I decided to use my afc and just street tune it before i bought it (since i had a check engine light for to rich/lean). Sure enough the miss went away. The car feels much stronger though out the rpm band. I still plan on dyno tuning and getting ignition but at least i found the problem. BTW i had to lean it out.
Old Mar 11, 2003 | 02:46 PM
_VTI-R_'s Avatar
Default Re: 7000 rpm and cut why?? (simike)
if yuo can tell me that in more easy word because i'm portuguese and i dont understand all??
Old Mar 12, 2003 | 02:50 PM
simike's Avatar
My problem was my car was running to rich.
Juan_Mitosis
Mar 11, 2008 12:18 PM
skivik
Nov 27, 2004 12:26 PM
corey's96GSR
Jun 5, 2004 09:34 PM
Speedz
Sep 10, 2002 06:06 PM
mattymatt
Jun 28, 2001 12:50 PM
