b2o turbo build up
Old Mar 11, 2003 | 09:34 AM
p1ccoloz's Avatar
Default b2o turbo build up
Looking to build a b20 turbo. Will probably be a long term project. But my question what's the best output you've seen for a b20 turbo? Post Dyno's or links if you can. Besides new rods, pistons, blockguard etc. what do i need to reinforce the block for heavy boost (say a good 15-18lbs)? Thinking of dropping it in a crx.
Old Mar 11, 2003 | 09:40 AM
liam821's Avatar
25 Year Member
Default Re: b2o turbo build up (p1ccoloz)
blockgaurd wont cut it...you pretty much have to sleeve b20 blocks or they break. They have super weak sleeves.
But once you do that..they are super fast. My friend ran a 12.6 @ 112 in a full weight full interior 95 coupe on small 14" slicks. That was at 10psi and 91 octane pump gas. On street tires his best was 13.08 @ 116..also on pump gas and 10psi.
broke b20 block after 12,000 miles of boost - 10psi.
liam
Old Mar 11, 2003 | 09:51 AM
p1ccoloz's Avatar
Default Re: b2o turbo build up (liam821)
ouch, whats the sleeving process and how much?
Old Mar 11, 2003 | 10:01 AM
BrokenVtec's Avatar
wow..... you got 12,000 miles out of that......
my b20 lasted me 1300 miles ALL MOTOR before my sleeves cracked
but now its sleeved and soon to be boosted so
Old Mar 11, 2003 | 10:17 AM
liam821's Avatar
25 Year Member
Its the process of cutting out the stock sleeves (removing them all together) and replacing them with huge iron monsters..they dont crack and can hold 45+psi of boost. The cost is around $700 -> $1500 depending on who you go with. There are alot of different sleeves out there now, golden eagle, AEBS, darton, JG, and a few others. I like golden eagle sleeves personally
4 Stroke put up some awesome pictures of his block he was selling...which is a golden eagle block.
https://honda-tech.com/zerothread?id=349843
liam
ChrisCoupe1
57
Dec 17, 2014 01:19 PM
jdmcivic1999
Mar 7, 2005 08:10 AM
Will Albers
Feb 23, 2004 04:16 PM
othick
Jul 31, 2003 07:35 PM
1sick4door
Nov 1, 2002 02:12 AM
