OBDII and straight pipes
Old Mar 11, 2003 | 12:19 AM
SSBP DC2's Avatar
Default OBDII and straight pipes
i have a 98 GSR, will i throw a CEL if i were to use a straight pipe?
do you guys think i should do this or just go with a bigger cat?
either way, the diameter will be 2.25
LMK, TIA
-demitri
Old Mar 11, 2003 | 01:42 AM
3rdGteg's Avatar
Default Re: OBDII and straight pipes (SSBP DC2)
yes, and yes; or u can get a racing cat, do a search in the archive .
Old Mar 11, 2003 | 08:27 AM
SSBP DC2's Avatar
Default Re: OBDII and straight pipes (3rdGteg)
thanks
Old Mar 11, 2003 | 11:32 AM
GM2000ITR's Avatar
New User
It appears that you live in CA, true? If so, won't you have a prob. w/ the po'-po' (no probs. here in FL)? Get one from testpipe.com They offer t.p.'s w/ a cat-material filled O2 bung for OBDII cars that will not trigger any CELs.
Old Mar 12, 2003 | 04:22 PM
pornstarSR's Avatar
i have a 98 civic obd2 with a test pipe i made
there is a way to get ride of the check engine light...
just dont put the second 02 back in the pipe after you put the straight pipe in....
all the 2nd 02 looks for is cross counts....so if its hanign in the air it wont see this and will not code...
the primary 02 is the only one that controls your engine
i have made 3 test pipes for various cars, all obd2, none of us have had check engine lights....
and we live in California, so yeah you have to be a tad bit careful, but where i live(santa barbara) the cost are too lazy to get on there knees and look under a lowered car...
[Modified by pornstarSR, 1:23 AM 3/13/2003]
Old Mar 12, 2003 | 06:10 PM
b18b98's Avatar
Default Re: OBDII and straight pipes (pornstarSR)
You could always do the old trick of wrapping your secondary 02 up with foil. Trust me..it works.
Old Mar 12, 2003 | 06:17 PM
sslude's Avatar
Default Re: OBDII and straight pipes (b18b98)
or you could to the OBDll workaround or an OBDll/OBDl conversion, which would be better overall
Old Mar 12, 2003 | 06:33 PM
98DC2's Avatar
Default Re: OBDII and straight pipes (sslude)
i agree...go w/ the conversion. it allows you to do more in the future....
Old Mar 12, 2003 | 10:09 PM
SSBP DC2's Avatar
Default Re: OBDII and straight pipes (98DC2)
thanks for all the posts guys
Old Mar 14, 2003 | 06:23 AM
MEANB18's Avatar
Another thing you can do is check out godspeed, they make a race pipe that o2 bung has three holes drilled in it, and catalytic converter material surrounding it, tricking the o2 sensor... Check out the site for full details
Old Mar 15, 2003 | 03:01 PM
3rdGteg's Avatar
So with the obd1 conversion, there won't be a check engine light if I use a straight pipe?
beastman@
Oct 19, 2007 08:20 PM
rbdynamics
Dec 15, 2005 05:46 AM
Dai_Ca_Vietnam_H22a4
May 21, 2005 08:42 PM
WhoisDan
Jul 18, 2003 10:21 PM
cvcTypeR
Mar 3, 2002 08:08 AM
