Idle problem with b16a
Old Mar 11, 2003 | 12:05 AM
xrayvi5ion757's Avatar
Default Idle problem with b16a
My car idles up and down at 3500 - 5000 rpm help me what is wrong i checked map sensor iacv and checked for vacuum leaks but there is none and I did not change my tps could it be my tps? plus when I covered one of the holes in the throttle body (theres two of them) then the idle settled down to 800rpm which is cherry but in the backround once in awhile it would start surging up and down from 1000-1500 rpm what is my problem and if i drive my car with one of the idle air holes covered in the throttle body would that damage my engine? please let me know thanks alot ahead of time......
Old Mar 11, 2003 | 12:24 AM
VR6T's Avatar
Default Re: Idle problem with b16a (xrayvi5ion757)
Things to look at first: Spark plugs, wires, distributor, fuel pump, injectors, cam timing (lash) and a compression test.
Have you done all of the above?
QuicksilverFX
Dec 30, 2014 11:12 PM
eg5b16
Jun 10, 2011 06:36 PM
94Integra_Ls
Feb 14, 2007 10:01 PM
wrXtian
May 6, 2005 12:37 PM
fishman
Aug 15, 2002 07:05 PM
