pics of maxrev oil supply/return lines?
Old Mar 10, 2003 | 09:28 PM
DoriDoriboii's Avatar
Default pics of maxrev oil supply/return lines?
I'm a little confused as to which fittings go where...i have a rubber aeroquip hose I know is the return...and the steel braided is the supply...but which fittings go where?
Old Mar 10, 2003 | 09:47 PM
LJR-LUDE01's Avatar
Default Re: pics of maxrev oil supply/return lines? (DoriDoriboii)
the blue and red fitting are for your retrun line... and you are missing the fitting that you weld to the oil pan..... it should be another blue fitting... that's in the max-rev kit.... the other big fitting you have is for your oil return that you install on the turbo... the t like you say is for the oil feed if you are using the ge adapter i think you can just hook you 1/8 npt to 3 -an ( which is the one under your two blue an red fitting)and the just hook up your ss feed line. the second fitting I didn't use... i when and got another 1/8 npt to 3 -an to hook to the other end of my feed line and into the turbo...
[Modified by LJR-LUDE01, 1:48 AM 3/11/2003]
boostedBLUfg2
Apr 12, 2011 06:46 AM
jacob4lester
Feb 16, 2010 08:36 PM
neoc03
Nov 2, 2009 07:54 AM
4cylsturbo
Aug 20, 2006 05:56 AM
iHOPEyouCHOKE
May 27, 2006 09:24 AM
