car wont rev up
Old Mar 10, 2003 | 05:39 AM
monkeypee's Avatar
Default car wont rev up
i have a 91 civic dx, i finally got the car to start and idle but it wont rev up when the throttle is turned. it did rev up a couple times but it would sputter and die when it did, every other time it wouldnt do anything. Sometimes it idles fine and other times the RPM's rise and fall and then it will stay constant for a while and then go back to rising and falling. It's not throwing any codes and i put new gas into it, so could this maybe be the fuel filter? if not what could it be?
Old Mar 10, 2003 | 08:27 AM
ScubaStevo80's Avatar
Default Re: car wont rev up (monkeypee)
I would have to say you're either not getting fuel under load. This problem happens alot on jetskis, so I'm assuming its something in you're fuel system that's not letting fuel through when pressure builds. Check the filter, lines, etc and let us know what you find...
Old Mar 10, 2003 | 08:42 AM
monkeypee's Avatar
Default Re: car wont rev up (VolpeOwnsU)
thanx for the reply, im gonna replace the filter today and see if that helps
95soul
Apr 9, 2010 10:28 PM
kornkid21792
Feb 14, 2010 02:06 PM
89canefighter
Mar 15, 2009 02:51 PM
bignosewhipper
16
Jul 3, 2008 05:38 PM
Mychal71
Aug 18, 2006 05:40 PM
