H22A Crank Timing Problem....help asap
Old Mar 9, 2003 | 08:19 PM
4bidden's Avatar
Default H22A Crank Timing Problem....help asap
Hey guys, I dont know if its been discussed over here as much as over on PO but a lot of ludes are having some hesitation problems. Well, in the quest to find what was causing my hesitation, I wanted to check my timing today. I popped the valve cover over, set #1 to TDC, pulled the plug on the tranny so I could see the flywheel. Here is where I am unsure....since #1 is at TDC, should the TDC mark on the flywheel be directly across from the "arrow" that you use when doing ignition timing? There are four marks on the flywheel, TDC, +12, +15, and +18 I think.
Can someone help me out on this? Shouldnt the TDC mark on the flywheel line up with the arrow? I did go from 3rd to 2nd at the track before all this happened. I had a problem with my linkage not being secured, thats why. Does it sound like I skipped some teeth on the timing belt? If that is the case, what is the best way to get it back to TDC? Also, did I skip some teeth on my crank, or is it coincidence that I just skipped the same amount of teeth on the cams because the gears are both lined up the same. Thanks for any help guys!!!
anomale
Nov 30, 2008 01:34 PM
pcguy760
May 21, 2007 07:53 AM
92 in the works
Feb 23, 2004 07:30 AM
4bidden
Mar 13, 2003 09:04 AM
H23ludedude
Feb 20, 2003 05:23 AM
