crank pulley bolt WON'T BUDGE
Old Mar 9, 2003 | 06:10 PM
warwagon's Avatar
Default crank pulley bolt WON'T BUDGE
i've got my motor out and pretty much dissasembled so i can get her sent out to get sleeved and i cant get the crank pulley bolt off, suggestions please
Old Mar 9, 2003 | 06:22 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: crank pulley bolt WON'T BUDGE (warwagon)
Well, it makes it a lot easier once the motor is out like you said. Have a buddy stand on the block. Jam a screwdriver into one of the holes of the flywheel, and get the biggest, baddest breaker bar you can find.
Then go at the ****.
Good luck. A powerful (at least 500ft-lbs impact gun would be helpful here )
Old Mar 9, 2003 | 06:23 PM
phattycrx90's Avatar
get a big air gun. if you cant then drill a hole in it and put an extension through it to hold it still
Old Mar 9, 2003 | 06:34 PM
shamoo's Avatar
Default Re: crank pulley bolt WON'T BUDGE (phattycrx90)
Hmm, that must do wonders on the crank balance.
Old Mar 9, 2003 | 06:38 PM
STHPERFORMANCE's Avatar
Default Re: crank pulley bolt WON'T BUDGE (shamoo)
Well if you had a garage like mine you would just get the Plasma cutter out and cut the bolt off like hot knife through butter
Old Mar 9, 2003 | 06:41 PM
Jared's Avatar
Default Re: crank pulley bolt WON'T BUDGE (Outkast)
I have a 3/4" air gun that has never failed to pull one off.
Old Mar 9, 2003 | 06:46 PM
shamoo's Avatar
Default Re: crank pulley bolt WON'T BUDGE (Jared)
But what is it's power? I have a 350ft-lb one and a 500ft-lb one. The bolt is supposed to be torqued only to 130ft-lbs, but I guess with all the heat and whatnot, it just gets on there real right or something. They both couldn't get my bolt off. I had to use a 5 foot breaker bar. And I nearly broke that in half.
Old Mar 9, 2003 | 06:48 PM
integra_gsr98's Avatar
Heat the bolt with a torch and then hit it with an impact gun. Works wonders on every one that I have ever removed.
Old Mar 9, 2003 | 07:02 PM
warwagon's Avatar
Default Re: crank pulley bolt WON'T BUDGE (integra_gsr98)
yeah i was kinda thinkin about hittin it with some heat and then tryin the impact some more
Old Mar 9, 2003 | 07:05 PM
drumking15's Avatar
Well considering all the things you all have mention, ive tried them all doing my friends prelude, and your big badass breaker bar consisted of a matco breaker bar with a 6ft pipe extension, did that work nope! My suggestion, go to honda or moroso and pick up the crank pulley tool for about 50 bucks! Its dam well worth it than messing up your crank...like if seen my other friends do. BTW go ahead and drill thru your cp and unbalance it, thats always a great idea. Not to hate in all, but break the flywheel tooth and might as well unbalance that too...sry guys but somethings just require the right tools and this is one of those things...Ya and one more thing a 1 inch are gun running on a huge **** compressor could take my freinds off...Overtime that 130ft lbs = hell...The solution = the tool and a breaker bar + 6ft pipe extension + 3 friends to break it loose...thats the answer good luck and have fun getting it off we all did!
Old Mar 9, 2003 | 07:50 PM
kyle h.'s Avatar
i got a 600 ft-lb gun the other day and it doesnt take mine off.
Old Mar 9, 2003 | 07:53 PM
kyle h.'s Avatar
Default Re: crank pulley bolt WON'T BUDGE (drumking15)
i called honda up the other day to get a price on it and they said they dont use a special tool or sell one. i swear i've seen a picture of the tool before tho...i hate the parts counter, those ******** dont know what they are doing (Jones Honda, Lancaster Pa)
Old Mar 9, 2003 | 08:12 PM
InevitableRace's Avatar
Default Re: crank pulley bolt WON'T BUDGE (kyle h.)
[QUOTE]i called honda up the other day to get a price on it and they said they dont use a special tool or sell one. i swear i've seen a picture of the tool before tho...i hate the parts counter, those ******** dont know what they are doing[QUOTE]
They are so stupid here too..One time i went to honda and i asked for an oil filter for my civic and the ******* guy looked up the part number in his computer... Stupid ***
You can get a crank pulley puller at Napa or autozone..you can basically get it at any car parts store...
Or you can do what i do.....
Step 1 take the black plate off the tranny
Step 2 take a pry bar and jam it in where the fly wheel teeth are.
Step 3 Get a Breaker bar and a long steal tube and place it over the breaker bar and pull..
Your going to need 700ft of tq to get that thing off..
Thats what it calulates out to be with a Breaker bar and a 4FT steal tube...
-Ross
[Modified by allmotrb18c1, 5:14 AM 3/10/2003]
Old Mar 9, 2003 | 08:20 PM
Therumblingteg's Avatar
that will work.
Old Mar 9, 2003 | 08:36 PM
Muckman's Avatar
Moderator in Chief
Crank Pulley Tool
http://www.thetoolwarehouse.net/shop/SP-60100.html
Old Mar 9, 2003 | 09:02 PM
Kamin's Avatar
Default Re: crank pulley bolt WON'T BUDGE (Muckman)
i got a moroso crank pulley tool and i LOVE IT
broke bolts free like buttah.
and the coolest sound is when it breaks free
i thought i broke (another) socket when it finally loosened.
[Modified by Kamin, 10:03 PM 3/9/2003]
Old Mar 9, 2003 | 09:06 PM
igyloo's Avatar
Mac 1/2" impact one bad *** impact
Old Mar 10, 2003 | 09:29 AM
warwagon's Avatar
Default Re: crank pulley bolt WON'T BUDGE (igyloo)
yeah, mac how much was that thing?
DaKINE-Ek
Aug 14, 2006 05:22 PM
tianporn
Dec 4, 2005 08:05 PM
jdmstreethatch
Apr 22, 2005 09:12 PM
BoostedED9
Jun 16, 2002 06:45 AM
