Question for you turbo people
Old Mar 9, 2003 | 08:04 AM
Toda Built's Avatar
Default Question for you turbo people
From what I have read on this site the Greddy turbo kit is a well put together kit and is a pretty good buy. And the only downside of the kit is the internal waste gate.
My friend came up with an idea about welding the internal wastegate off or closed and putting your own external one in. Would there be any benefit to doing this or is it not worth the time and effort
Its just a thought and nothing that I have gone into to much depth about. I just thought that I should ask you guys who have more knowledge on this subject than i do.
Old Mar 9, 2003 | 08:14 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Question for you turbo people (SH_LUDER)
his idea won't work, i promise, b/c i've researched it
Old Mar 9, 2003 | 12:17 PM
drift's Avatar
New User
yes, it's doable. a lot of Garrett/AiResearch T3 housings are 5 bolt config with an internal wastegate and use a blocker plate in place of the flapper valve housing to accomodate an external wastegate setup.
just need to find a welder who can weld up cast iron... hard to find someone who's truly competent, tho.
look up information on mitsubishi turbines. DSM guys are very familiar with them, and may already have housings that are designed for external wastegates. a bit hard to find, as many DSM owners swap over to a Garrett style turbine instead as the parts are more readily available.
3easy21
Oct 27, 2012 12:09 PM
blwnengnls
Apr 12, 2007 06:40 PM
EF9_R_Killa
Sep 21, 2004 04:35 AM
phthalo
Jun 2, 2003 08:10 AM
metal-x
Nov 8, 2002 07:14 AM
