quick question before ordering a turbo
Old Oct 27, 2012 | 10:33 AM
3easy21's Avatar
Default quick question before ordering a turbo
one of the options says i can get it with or without wastegate hole. I am going to be using a external tial 38mm wastegate. So I should I get the one with out, correct?
Old Oct 27, 2012 | 10:39 AM
grumblemarc's Avatar
The Grumpiest
Default Re: quick question before ordering a turbo
Order WHAT with or without wastegate "hole"?
Old Oct 27, 2012 | 10:45 AM
3easy21's Avatar
its a precision 3431
"This Entry Level unit features the following:
• 57mm inducer compressor wheel
• "E" compressor cover 3.0" inlet/2.0" outlet
• 57mm exducer T31, 76 trim turbine wheel
• Turbine housing options:
- T3 .48 or .63 A/R with 4 bolt discharge
- T3 .48 or .63 A/R with 5 bolt discharge (with or without wastegate hole)
• 360° journal bearing system"
Old Oct 27, 2012 | 11:54 AM
3easy21's Avatar
http://www.enjukuracing.com/products...bocharger.html
Old Oct 27, 2012 | 11:57 AM
wantboost's Avatar
Who is Mr Robot?
Normally the external wastegate is mounted to the turbo manifold pre turbo. Assuming yours is setup this way (it should be) then no you don't need it
Old Oct 27, 2012 | 12:09 PM
ryukincrx's Avatar
I would contact your manifold manufacture to see how your turbo kit is setup? Precision Turbo is also extremely knowledgeable and helpful on the phone as long as you know how your manifold is set up.
Most manifolds have the wastegate vbanded to the manifold.
4g4dcruisin
Aug 30, 2009 04:30 AM
BlackEG6
Dec 4, 2005 07:29 PM
SpoolnByYou
Dec 2, 2005 11:14 PM
brnzbuddha
Feb 4, 2005 07:46 AM
