Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
newbie turbo question...
Old Sep 16, 2004 | 09:07 PM
EF9_R_Killa's Avatar
Default newbie turbo question...
Since Im not authorized to post in the F/I thread for some reason...I need to know what all I need other than a exhaust manifold for my b16 in a crx if I pick up a sohc greddy trubo kit from a friend. How will a manifold with an external wastegate act with the greddy turbo that has an internal one? also any suggestions for fuel/air control on a stock motor.
Old Sep 16, 2004 | 09:13 PM
Smokinsax's Avatar
The Boot
buy the b series mani that will bolt to the greddy turbo. If it has an external wastegate flange then you can buy a block off plate so you can use the internally gated turbo. Otherwise you need a different down pipe if you go with an external wastegate.
Old Sep 17, 2004 | 08:44 AM
kewl, thanxs mayn....wait do you mean just a dump tube for the wastegate and or an actual different down pipe off the turbo as well?
Old Sep 20, 2004 | 02:40 PM
daym, nobody wants to help a brotha out?!
Old Sep 20, 2004 | 04:57 PM
honda_joe's Avatar
Default Re: (EF9_R_Killa)
The TURBO downpipe won't change regardless of the wastegate choice. You will have to add a dumptube if you run the external unit.
Old Sep 20, 2004 | 06:43 PM
TurboTeG4's Avatar
Default Re: (honda_joe)
Good Luck to You
Modified by TurboTeG4 at 7:51 AM 9/21/2004
Old Sep 21, 2004 | 04:35 AM
murmur9's Avatar
Default Re: (TurboTeG4)
ABK
Dec 13, 2007 04:19 PM
phthalo
Jun 2, 2003 08:10 AM
metal-x
Nov 8, 2002 07:14 AM
