Help, just installed motor...
Old Mar 8, 2003 | 03:37 PM
BlkSIvic's Avatar
Default Help, just installed motor...
Just finished putting another b16 in my 99si the problem is the car idles well until I hit the gas then the revs drop almost until the car stalls. then when I give it more gas it hesitates before it build revs
I'm getting no engine codes either
[Modified by BlkSIvic, 3:54 AM 3/9/2003]
Old Mar 8, 2003 | 03:42 PM
leadfoot78's Avatar
Default Re: Help, just installed motor... (BlkSIvic)
so many threads about this, vacum lines not right or sensor connectors switched between the tps and something else, next time search and post what engine and what car. are you new?
Old Mar 8, 2003 | 05:30 PM
civicrtype's Avatar
I had a similar problem but probably worse, but first try to check if the tps and map sensor are switched cause when u switch em, when u hit the gas the car will die, happened to me. But here's my thread, alot of good info so check it out: https://honda-tech.com/zerothread?id=433852
mister.wong
Jan 14, 2009 03:48 PM
Al-sonic
Jan 9, 2007 01:10 PM
crush
Sep 11, 2005 01:12 AM
slowEm2
Nov 9, 2004 11:02 PM
gambit1982
25
Dec 18, 2003 09:17 AM
